Make:
Nissan
Model:
Skyline R33 GTR V-SPEC
Milage:
62,xxx km
Transmission:
5 MT
Colour:
Dark grey pearl
South eastern suburbs, Melbourne
Complied?
Yes
RWC supplied?
No
Currently registered?
Yes, July 2009
Price:
$24,500 NEG
Contact:
PM or call/SMS 0416 623 381
Comments / Modifications:
After an eventful weekend, in 27 days I will have no license for the next 6 months so at this stage I have no need for this car at all..
I haven't owned it for long but it has been very well looked after in the period I have had it, only problem that it has is the 4th gear synchro's in the gear box. Common problem with the GTR box, on some occasions it will crunch into 4th gear but can be avoided by double clutching etc
Its nothing major that and doesn't affect performance in any way and the box is perfect in every other aspect, it may still last a life time. Easy fix if you have the box out, its a $120 synchro + labor
Always serviced with MOTUL oils and motor is very healthy, never misses a beat. Oil pressure reads perfect on all occasions
Very quick and reliable street car, not to mention legal. Exhaust is quiet, ride height is legal and there is only 1 induction mod so nothing detectable
Factory options include
- Active LSD
- Drivers and passengers air bag
- Upgraded V-SPEC altessa system
- Brembo brakes
Other mods
- Series 3 V-SPEC cluster - 10,xxx km
- DAN666 LED lights in cluster and din gauges
- Greddy auto turbo timer
- Apexi Power FC
- Splitfire coil packs
- Custom piping kit
- Trust pod filters
- XS Power front pipes - New
- JJR type 2 cat replacement pipe - New
- Trust copy 3" cat back exhaust - New
- Work Emotion XD9 - 18 x 10 + 18 - New
- 235/40/R18 tyres - New
- Japanese brand lock/wheel nuts - New
- PIONEER DEH6050UB head unit
- Slotted front rotors
- New interior floor carpet
- XTREME HD clutch
- Lightened flywheel
- SUPERPRO adjustable caster kit
- SUPERPRO adjustable camber kit
- Alarm & immobilizer
Some service history from CHASERS Motorsport as the previous owner used to take it there, about 2k in receipts for servicing and maintenance
Also has 1k in receipts from CENTRELINE as they did the bushes and an alignment. I have receipts for when I had the car re tuned, also dyno graphs to show power output
Car makes 230kw at all 4 wheels on a lazy 13psi, that was with the old leaky exhaust. With this new exhaust setup it will surely make more power and also a lot quicker, I can feel it being more responsive and strong up top as well. Has plenty more left in it, with CAM gears and a more aggressive tune, boost up to 14 - 15psi it should see in excess of 250kw
Any comments or interest please PM me, I have had to make a new thread because the last one just has too much rubbish
Thanks
Images:
lol get ur beast to make over 200 kw before jumping into the ring :)
good luck with sale anyway, been in this car and had a quick check over of underneath and engine bay while up on the hoist all in good nick!
saw the car on Saturday and did go over it and for the price it is an awesome buy.
them white wheels makes it look oh so so so fat lol and exhaust has a nice not so loud but tough note.
small things like the seat shouldn't worry anyone. it still holds the driveer as good as it did before.
gluck with the sale abu.
I too drove this car last week and it is a genuine GTR, wheels look great and the car drives great. A real bargain for anyone in the market for a 33:)
Looks great, I feel your pain trying to sell, the white wheels suit it well, but it takes me back to when mine had them and trying to keep them clean, one drive and the fronts are filthy, looks the same on yours!
Free bump for you anyway!
Edited by QIK_GTR
    • It's (the TPS) buzzing? Or something else is buzzing in response? Remove the IACV from the plenum. Block the hole into the plenum with your hand. Get someone to start the car. Let some air is. Do the revs flare up? This is checking that the path into the plenum is clean. After that, is the air hose leading to the IACV fuly clear? After that, either you didn't clean it thoroughly enough to allow the valve to move, or it is broken.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
