Make: Nissan
Model: R34 GTR
Milage: 59xxx
Transmission: 6 spd man
Colour: Black
Complied? Yes
RWC supplied? Yes
Currently registered? Yes
Price: $48,000
Contact: 0404 453 542
Comments / Modifications: HKS cat back, LMGT4 18" mags
Images: Yes
I have decided to sell my R34 as I dont ever drive it. I am the first owner in Oz, first registered in March. It has a HKS cat back that Ben at RacePace fitted, and a set of LMGT4 Nismo mags. Still has 180kmh limiter, standard cassete deck. No marks, inside or out.
I will be replacing it with an R32 or R33 GTR as I will always own one, I simply cant justify having this much money sitting around not being driven.
https://www.sau.com.au/forums/topic/237015-black-r34-gtr/
  • Replies 87
  • 1 month later...
Its not just the dollar. This is not my first GTR. The last one made close to 500awkw, I sold it for $30,000, it was mint, flawless. I see guys asking for $50,000 for R32's ffs that wouldnt hold a candle to my last effort.
I'm all for maximising what you can get, good luck to them if they can get it. I see someone is trying to get close to $140,000 at the moment. Very hard to get $$$$$$$$ back for mods. Thats why no mods this time, just a perfect mint black R34 GTR, with the best wheels ever made for a GTR (my opinion).
My price is based on the condition of the car, the price others are asking. I get my licence back in 4 weeks, not as important if I sell it or not now, but its worth more than a modified 32 or 33 in my opinion, alot more. I speak from experience.
I hope everyone gets what they want for their 32's and 33's by the way, I love all GTR's.
https://www.sau.com.au/forums/topic/237015-black-r34-gtr/#findComment-4251297
  • 3 weeks later...
You have no idea how tempting that idea is. I rate your GTR in the top 5 GTR's in Australia. I recently got out of a 450 rwkw GTR, and I really really miss it. Its just that I hope I am getting old enough to realise highly modified GTR's are a dead end money pit, regardless of the fact they have no equal on the road.
Let me think about it, getting it registered in Vic is my biggest hurdle. I know I'm probably going to do this, and get a divorce lol
I'll let you know shortly. Thank you for the offer. Your not going to believe I already own RH9GTR number plates lol
https://www.sau.com.au/forums/topic/237015-black-r34-gtr/#findComment-4293661
All pm's replied, I cant believe the sudden interest 10 days before I get my licence back.
Smurf, what is your car worth ?
Paul I'm just checking with Vic Roads what I need to do in regards to getting it registered. I would realy love to own Twoogle.
John, I'd rather sell it with the wheels on.
Nick, let me work out what it will cost.
https://www.sau.com.au/forums/topic/237015-black-r34-gtr/#findComment-4298670
She'll be up for sale for $25,000 in the next day or two. 2008, Red, sunroof, only 30,000kms (90% highway kms). APR tuned ecu so it's a bit nicer to driver (152kw and 330nm torque), still regularly get 7.2litres/100km per tank.
PM me your email address if you want some pics. Was actually putting it up for sale to buy something cheaper so I can save for a stock R34 GTR, but this thing is too good to pass up.
https://www.sau.com.au/forums/topic/237015-black-r34-gtr/#findComment-4298708
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
