i have a R32 GTS4 "AUTO".. i really really really want to change it to a manual :P but don't really want to fork out the $1500 for a gtr gearbox... what i would like to know is if a r32 or r33 GTST manual gearbox will bolt upto the transfer case off the auto? cos i know it will bolt upto the engine...
i was told that a r33 gtst gearbox is stronger so will either one of those fit the transfer case?
and with the auto gearbox what wires are connected to that, that i won't need on the manual?
i'm getting tired of not being able to change gears...:D
https://www.sau.com.au/forums/topic/23702-gts4-gearbox-question/
Originally posted by Mr GTS4
...i'm getting tired of not being able to change gears...:D
Of course you can changer gears :uh-huh: Every auto I've ever driven gets driven like a manual, ie change down a gear or 2 when approaching a corner, or crank it back to 1st at a set of lights.
I wouldn't expect a RWD 'box to simply bolt up to the side of the t-case to give 4WD. Maybe a genuine GTS4 'box would be cheaper than a GT-R 'box.
I've never seen the R32 GTS4 manual box however the auto is a standard RE4R Nissan piece with the 4th housing the transfer case. In the non-4WD models, the auto is identical with an extension housing in place of the transfer case.
The R32 gearbox is the weak type compared to the R33 GTS25t type and I doubt the 4WD transfer case will bolt up since its a 3 piece device. Can anybody else shed some light or get a photo of the 4WD GTS4 manual box, or is it identical to the GT-R box?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
