"adaptronic" Engine Management Systems ?
Yea - Needs a side shot TBH. Other than that, actually looks pretty good. My OCD would want to see it tuck 'higher' but melty melty is a concern.
Yep, mine works perfectly. Did you work off the wiring diagram here? https://www.haltech.com/wp-admin/admin-ajax.php?action=ht_get_file&id=633e67ff2f02d268520a8812&op=1 -
Please do a follow up post after a few spirited drives, curious to see how the coating and tyre "shine" holds up.
I suspect you probably need to connect to both, possibly with diodes in each side to prevent backfeeding. You really should be able to see how they did it originally in the wiring diagram.
