Hey Guys
Im sure this may have been asked before.. but here goes...
I am sick and tired of my standard computer. The biggest let down of my R33 skyline has been the standard computer and the fuel cut problem. Air flow meters drive me crazy and I want to get rid of it once and for all. Fuel cut defenders drive me crazy.. Sick of getting dyno read outs at 95ks an hour because it hits fuel cut rah hah rah
I can get a Microtech LT12 for my R33 for $1550.00 (No hand controller)
OR
I can get a APEXi D Jetro PFC for $1,103.00 and $1,462.00 with HC (this version gets rid of the air flow meter so I wont have to worry about that)
OR
APEXi SAFC2 or similar.
My mods are
T3/T4 hybrid turbo (no ceramic rear wheel)
Supra Front mount
cold air injduction & K&N
3" HKS exaust
Would a SAFC2 do the job? or should i get a APEXi D Jetro PFC and just be done with it ?
I am after 225rwkw and plan on doing the RB30 upgrade within the next three months too.
I think the S-AFC will give you problems with the bigger turbo as its only controlling fuel and the ECU will need more than just fuel map adjustments to suit the larger turbo properly.. but it will fix the fuel cut problem.
I think you're best with the PFC unless you are going to have troubles finding somebody who can tune it properly. Otherwise the microtech in capable hands should do a similar job. Either will probably be a better choice than the S-AFC
I'd go the Power FC if you have someone to tune it up properly....I wouldn;t be in too much of a hurry to get rid of the AFM either.
I currently have the EMS Dual Sport and will probably change to a PFC when I can afford it
If you say that i should keep the Air flow meter.. but doesnt the air flow meter have a limit to how much power it can make? Wouldnt I have to upgrade to a Z32 AFM ?
If so.. whats the point? stuff the AFM off and go map sensor I say..
So why keep the AFM?
the afm is supposed to be more accurate than a map sensor. so if your going for the extra tunability of the power fc then youd be better off with more accurate readings.
i read somewhere on here that the rb25 afm is good up to 250 rwkw, but dont quote me.
Engines with an AFM will usually be more driveable and have better fuel economy.
Depends how far you want to go... If your not going to change the turbo and what to keep it fairly driveable, go the PowerFC.
The older Microtechs give poor fuel economy but make good power. I don't know if the newer models are any better.
Here's the same advice I give anyone. If you have the bucks, get the PowerFC. If you don't, rather than waiting and saving up until you can afford one, get a S-AFC (or S-AFC2) new or second hand (preferably second hand). Then tune that and start saving for your PowerFC. When you have almost enough, sell the S-AFC and use the cash to partially the PowerFC.
With this approach you will probably find you can live longer without an ECU replacement. And you will get most of your money back on the S-AFC so you haven't really lost much money, but gained a pretty good state of tune while you wait for the PowerFC to become affordable.
I think that I have read just about all the threads on this forum about replacement ecu's and as yet can not form an honest opinion on which is better. The PFC certainly has a good reputation but is a little on the dollar rich side whilst the Microtech range appear to offer a good product at the less expensive price range. One thread started to talk about fuel consumption but nothing really substantial was forthcoming. Can anyone who has the PFC and anyone who is using the latest Microtech (LTX-12) please post some honest consumption figures. I think we all agree that both ecu's have the capacity to enable the engine to produce good hp results (when combined with various other mods) so let's see the consumption figures please.
Cheers
how is the microtech less for an R33 ??
You can get a PFC from nungen or greenline for about $1500 with hand controller.
Its the same price for a microtech for me but i get a good price. they are $1800 otherwise with no h/c
Oh!
Sounds like a PFC is the way to go if there is someone around your neck of the woods to tune it. All the info on these threads seem to point towards the PFC as the ecu of choice. Post your consumption figures when you get it in and running. I'm not too interested in what power/torque it will make for you but the fuel consumption side is more of an interest for me. If they are as economical as these threads would have us believe, then I will have an LTX-12 for sale pretty soon.
Cheers
So what's the story on the Z32 AFM upgrade with the Power FC ??
Why would anyone do that ?? What is the benfit ??
How good is the standard RB25 AFM ?? Up to what power can it go ??
What about the injectors and the turbo ??
I'm looking for 230-240kws at the rears.
Would the standard turbo, injectors and AFM handle this if i put a APEXi Power FC ??
Just done an engine conversion, put in a Rb25det into a vl and have replaced standard comp with Microtech. Best and cheapest alternative for all occasions. But I got next model up with hand and external coil driver for a lot less 12 or 13 hundred I think.
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
