Hey Guys
Im sure this may have been asked before.. but here goes...
I am sick and tired of my standard computer. The biggest let down of my R33 skyline has been the standard computer and the fuel cut problem. Air flow meters drive me crazy and I want to get rid of it once and for all. Fuel cut defenders drive me crazy.. Sick of getting dyno read outs at 95ks an hour because it hits fuel cut rah hah rah
I can get a Microtech LT12 for my R33 for $1550.00 (No hand controller)
OR
I can get a APEXi D Jetro PFC for $1,103.00 and $1,462.00 with HC (this version gets rid of the air flow meter so I wont have to worry about that)
OR
APEXi SAFC2 or similar.
My mods are
T3/T4 hybrid turbo (no ceramic rear wheel)
Supra Front mount
cold air injduction & K&N
3" HKS exaust
Would a SAFC2 do the job? or should i get a APEXi D Jetro PFC and just be done with it ?
I am after 225rwkw and plan on doing the RB30 upgrade within the next three months too.
I think the S-AFC will give you problems with the bigger turbo as its only controlling fuel and the ECU will need more than just fuel map adjustments to suit the larger turbo properly.. but it will fix the fuel cut problem.
I think you're best with the PFC unless you are going to have troubles finding somebody who can tune it properly. Otherwise the microtech in capable hands should do a similar job. Either will probably be a better choice than the S-AFC
I'd go the Power FC if you have someone to tune it up properly....I wouldn;t be in too much of a hurry to get rid of the AFM either.
I currently have the EMS Dual Sport and will probably change to a PFC when I can afford it
If you say that i should keep the Air flow meter.. but doesnt the air flow meter have a limit to how much power it can make? Wouldnt I have to upgrade to a Z32 AFM ?
If so.. whats the point? stuff the AFM off and go map sensor I say..
So why keep the AFM?
the afm is supposed to be more accurate than a map sensor. so if your going for the extra tunability of the power fc then youd be better off with more accurate readings.
i read somewhere on here that the rb25 afm is good up to 250 rwkw, but dont quote me.
Engines with an AFM will usually be more driveable and have better fuel economy.
Depends how far you want to go... If your not going to change the turbo and what to keep it fairly driveable, go the PowerFC.
The older Microtechs give poor fuel economy but make good power. I don't know if the newer models are any better.
Here's the same advice I give anyone. If you have the bucks, get the PowerFC. If you don't, rather than waiting and saving up until you can afford one, get a S-AFC (or S-AFC2) new or second hand (preferably second hand). Then tune that and start saving for your PowerFC. When you have almost enough, sell the S-AFC and use the cash to partially the PowerFC.
With this approach you will probably find you can live longer without an ECU replacement. And you will get most of your money back on the S-AFC so you haven't really lost much money, but gained a pretty good state of tune while you wait for the PowerFC to become affordable.
I think that I have read just about all the threads on this forum about replacement ecu's and as yet can not form an honest opinion on which is better. The PFC certainly has a good reputation but is a little on the dollar rich side whilst the Microtech range appear to offer a good product at the less expensive price range. One thread started to talk about fuel consumption but nothing really substantial was forthcoming. Can anyone who has the PFC and anyone who is using the latest Microtech (LTX-12) please post some honest consumption figures. I think we all agree that both ecu's have the capacity to enable the engine to produce good hp results (when combined with various other mods) so let's see the consumption figures please.
Cheers
how is the microtech less for an R33 ??
You can get a PFC from nungen or greenline for about $1500 with hand controller.
Its the same price for a microtech for me but i get a good price. they are $1800 otherwise with no h/c
Oh!
Sounds like a PFC is the way to go if there is someone around your neck of the woods to tune it. All the info on these threads seem to point towards the PFC as the ecu of choice. Post your consumption figures when you get it in and running. I'm not too interested in what power/torque it will make for you but the fuel consumption side is more of an interest for me. If they are as economical as these threads would have us believe, then I will have an LTX-12 for sale pretty soon.
Cheers
So what's the story on the Z32 AFM upgrade with the Power FC ??
Why would anyone do that ?? What is the benfit ??
How good is the standard RB25 AFM ?? Up to what power can it go ??
What about the injectors and the turbo ??
I'm looking for 230-240kws at the rears.
Would the standard turbo, injectors and AFM handle this if i put a APEXi Power FC ??
Just done an engine conversion, put in a Rb25det into a vl and have replaced standard comp with Microtech. Best and cheapest alternative for all occasions. But I got next model up with hand and external coil driver for a lot less 12 or 13 hundred I think.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
