Hi,
During respray, the painter misplaced the "Used Import Plate" pink/purple/magenta coloured label in the engine bay (see page 6 of: http://raws.dotars.gov.au/download/PDF/Pla...ort%20Plate.pdf to see what I am referring to).
I rang the guy who I bought the car from who originally imported the car, and he said there was nothing he could do about it and didn't know what I could do about it.
How can I get a replacement?
https://www.sau.com.au/forums/topic/237053-replacement-used-import-plate/
well refusing to pay for the job is not going to really do you any favours. and will just majorly piss off the panel beater. BUT he certainly does need to help get another one, and pay any costs involved in getting it. I would contact DOTARS and ask them what can be done about it.
Just peeling it off voids the label. If he finds the voided label, great, but not necessary.
You have to go back to the workshop that complied the car and get them to do a stat dec to get a new plate issued.
We just had to do this last week for a customer who put the wrong plate on a car.
Hi,
"You have to go back to the workshop that complied the car and get them to do a stat dec to get a new plate issued."
What is a stat dec? Can you please tell me what is involved ?
stat dec is a statutory declaration
After contacting DOTARS, unfortunately, it seems that the answer is simple.
A replacement plate cannot be issued for a vehicle that has been previously registered in Australia.
To be honest, I find this utterly ridiculous: there is NO WAY to get a replacement plate.
Mate its like trying to get a replacement plate for a brand new FG Falcon or VE Commodore.
Try asking for a replacement plate for your genuine A9X Hatch thats plates were destroyed when it was acid dipped during restoration??
You cant get replacement plates for any vehicle.
DOTARS is a federal system, rego is a state system. Their only major links are through NEVDIS or the online evidence databases that some state transport agencies (VICRoads, etc) use.
As far as I know, DOTARS has no way of knowing if a car's registered or not. Are you sure you were speaking with the RAWS team at DOTARS? It's a big agency so make sure you spoke with the right people. The other people at DOTARS don't know much about RAWS.
The car we dealt with wasn't yet registered, but we got the plate fine.
sounds a little dodgey to me that he "misplaced" something that important. ^^^ as above. Dont pay for the job until its found and re-attached.
this is exactly what dotars will think unfortunetly . their primary concern is rebirthing which smash repairers and painters are often involved in so their unlikely to take anything onboard from your spray guy.
can you produce the old "voided" plate , if he peeled it off. That will help a lot as they will know the location of the old plate. Your next best bet is to contact the compliancer and try and get him to confirm the identity of the car and get involved.
re-issuing of a new plate is not as hard with the raw if its close to the issue date , say if it was lost on arrival or put on the wrong car. but getting one issued to the public after some time can be very difficult.
I also think the painters story sounds a bit dodgey , i dont like your chances in this unfortunetly
Carizma: Thanks for the reply, the person I spoke to was Raws Administration...
The sticker/plate is gone, no chance of getting it back, and unfortunately no it's not close to the issue date (car was complied/imported 2 years ago).
Edited by mikegg
no worries.
Well, that's strange that they said that. The RVCS scheme has a circular (0-3-2 if you're interested) that says:
"The manufacturer must replace any label found to be defective. A replacement adhesive label or a letter of compliance may be provided where a lost or accidentally damaged label can be proven."
It's a different scheme than RAWS, but they both use similar adhesive labels so I guess you need to look into a 'letter of compliance' option then.
We've never done this, but maybe someone else here has. Get your painter to write you a letter saying what he's done, cause you might need that when dealing with DOTARS. Plus, it might be handy when you sue his az later.
Their should not be a problem if it has been registered before as your state registration authority will just issue you a letter stating the compliance plate is not fitted but is a legit car. It happens to AUS delivered cars as well when the plates are stolen off cars be it joy riders or thieves, I have seen it a few times over the years but the panel shop might get a fine.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
