Item:RB26dett, gearbox, tail shaft, front shaft, loom,computer
Age:r32 GTR
Condition:good condition
Price:$5900
To Fit: (What car)GTR
Contact:Mike 0423 849 355
Comments:got this motor from japan imported it myself. was going to put it in my gtst but ran out of funds so need some money to finish project. engine has 115K. both motor and gearbox are in good condition. comes with motor, gearbox, loom, all accessories, drive shafts. here are some pics.
feel free to ask questions
thanks
post-17389-1222052730_thumb.jpgpost-17389-1222052828_thumb.jpg[attachmen
=181588:22092008045.jpg]
https://www.sau.com.au/forums/topic/237058-rb26dett-gearbox-complete/
have you seen the prices of a brand new 34 N1 engine out of Japan they are around 5k.
No, they are not.
Warning issued - If you post garbage in other peoples sale threads again you will be banned from the classifieds.
Please respect other members - If you have a problem with an asking price, take it to pm.
Is the gearbox a push or pull? If it's a push type how much do you want for it?
How much do you want for the standard turbos?
how do you tell if its a push or pull type? i have someone interested in the whole engine so not going to seperate the turbos from motor just yet. see if it falls through.
thanks
  • 1 month later...
  • 2 months later...
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
