Item:R33 gtr wheels
Age:12 yrs
Condition:average for the age
Price:$1200 ono
To Fit: (What car) you know if u want them
Contact:Anthony 0433387334
Comments:Prefer pick up but can post at buyers expense
https://www.sau.com.au/forums/topic/237063-r33-gtr-wheels-with-near-new-rubber/
they got 225's on them. dont know the brand. just newies when it got complied a month ago.
no previous repairs to the wheels
they have gutter rash but thats how i got them. Not buckled though
as for pics they are gtr wheels. My scanners stuffed so cant upload pics sorry.
Can you please check the tyres - brand and model, as without this info, I cant tell you if I would want them or not.
Thanks,
George
tyres are "yellowsea" they grip fine.
and pkmike i cant reply to your pm re the wheels cause somethings wrong with my pm reply.
just call me on the phone number in my first post.
cheers guys
got any pics please can you post them up when u can' interested in the rims would you send it via courier or isit pick up only.?
  • 3 weeks later...
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
