  • Replies 72
i think SAU for those that are interested should make a indoor and outdoor team
I am for either or both
outdoor is a little more relaxed and bit of fun
indoor is just fast paced and hectic
try to see if we get enough people for a outdoor team then try to join a league or something
And +1 for annual matches with NS or other clubs for that matter
we could have a annual event of Soccer, cricket, footy, rugby....or whatever
it will be a great fun i reackon
https://www.sau.com.au/forums/topic/237096-cricket/page/2/#findComment-4149526
cricket, hmmm, I am too asian for it, too short, too little, not strong enough to hold the cricket bat (thus can't swing it properly), can't throw the ball properly (usually goes upwards for some reason instead of forward), can't run fast enough, sigh, being asian, you know..... sucks..... :D:banana: :banana:
More than half the people that play cricket in the world are Asian :P. I use to play back in school through to part of uni...also on occassions played some indoor cricket for Blacktown in Sydney. But, yeah spending 5 odd hours of ya wkend in 40degree heat wasn't always fun...nor was facing A grade and state bowlers :P:banana:
https://www.sau.com.au/forums/topic/237096-cricket/page/2/#findComment-4149528
I play for Ingle farm and we are in A2 and B2 i think, but we could be in B3 this year.
I am in between the A and the B grade side.
I was at Ingle Farm for a year, they were my second club, i was playing at Jets at the time and used Ingle Farm as my fall back club if i didnt get selected. Fortunately i played the whole year :D now Billsy and Chris Hannon (who used to play for us) are playing for us :O
https://www.sau.com.au/forums/topic/237096-cricket/page/2/#findComment-4150081
I played at prospect and TTG for a while and then went to play for Walkerville and opened the bowling for them in their premier grade side.
Now i am just out to enjoy and play where ever they put me at Ingle Farm which will probably be the B grade side this year again unless i can get fit and back to my old self as i have a good year with the ball.
Edited by Evil34
https://www.sau.com.au/forums/topic/237096-cricket/page/2/#findComment-4150106
Think ive seen you car around mate.
was it for sale on the side of the road once ?
I know some ppl at ingle farm too. kiwi, muller, and a few other boys that play.
https://www.sau.com.au/forums/topic/237096-cricket/page/2/#findComment-4150168
no that would of been my mates 'R34' same colour and same amount of doors :)
https://www.sau.com.au/forums/topic/237096-cricket/page/2/#findComment-4151396
  • 3 weeks later...
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
