Rule of thumb, try keep power one side / signals, audio other side. It is possible to hear even an indicator noise thru rcas when the wires run together. just keep the rca's to the opposide and you will be fine. (when Cable is run from engine bay to boot). This of course does not apply to cars with batteries in the boot
I have run the RCA's and spk cables down the left side of the car (under the carpet), but when running up through kick panel I discovered the ECU - is is the ECU right? Anyone had interference problems from this? While i am at it - anyone know the process of getting cables into the doors; i know how to remove the door trim, but it looks like you have to remove a bit of dash/glove box to get to the port between car and door.
Cheers,
Matt
unless someone else knows, i will try and document my attempts at rewiring doors. Hippy let me know if you beat me to it... might tackle easier jobs like sub box building/boot mdf work in the meantime.
  • 8 months later...
i know this is an old thread, but i'm after info of where/how is the best point to get the RCA's through the rear seat???
I've taken off the bolts to the bottom part of the rear seat (coupe) and tried to move the seat. This did not move it at all, i also didn't want to try and force anything as i don't know whats under there.
If anyone could inform me of how to get the rear seat out that would be good. :)
Chris: ok, but what is there involved in taking out the bottom half of the seat???
Just take the 2 bolts out and pull up??? And then work on the upper seat??
Check out this pictorial guide for more of an idea of where the bolts/clips are.
http://www.skylinesaustralia.com/forums/sh...ad.php?p=794357
j
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
