Hi,
I have a 95 GTR r33.
Looking at getting the wheel re-covered...
Not sure wheather to recover the whole thing, or just the air bag part or just the outside parts...
Can people post pics of what they have had done for some ideas...
cheers!
https://www.sau.com.au/forums/topic/237100-re-covered-steering-wheels/
^^ as above i'd love to see too.
Btw, Adam at one stage CarToys (Hindmarsh) did recovering, they looked pretty good.
might get a quote from them cheers.
And mate that does look great! did they do it with wheel on or off? Who did it?
Also with an airbag wheel, whats the go covering the centre part? Can it be done, or more to the point should it be done???
that looks awsome i gotta get this done for my 32 when its back on the road
ohh and sambo i still gotta grab that gear knob off ya..i totally forgot :rolleyes: soz dude i'll msg ya tonight
That looks pretty sweet bro. Did you have to take off the steering wheel yourself and leave that with them? Which company did you use?
cheers guys, yep i took the steering wheel off first. willshire motor trimmers on south road did the job for me :)
Edited by Sambo33
ohh and sambo i still gotta grab that gear knob off ya..i totally forgot :) soz dude i'll msg ya tonight
no worries vinnie, i been busy as too, yep just send me a msg when u wanna pick it up
U would'nt be able to get the airbag module recovered as it is made of special material that folds open when the airbag deploys. i would suggest trying armoural on the airbag or failing that maybe even try shoe polish.
As for the wheel, reckon red stitching would look nice
im pretty sure my mates company has the fabric for airbags, i'll have a chat to him about it
http://www.blackneedle.com/blackcontact.html
if you feel you want to chat to them yourself - they are opposite Hitman/Race solutions
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
