Well Seeing as i can't update the price on the old thread i decided to make a new one.
1996 R33 NISSAN SKYLINE GTST
Mileage is 105,000 with 100,00 service completed
Registration untill 26th April 09
Fully Engineered aka police friendly
EXTERIOR
Unique and rare Tommi Kaira front bar
Type M factory side skirts and rear Pods
Stealth rear wing
Nismo clear side indicators
18” Shadow Chrome Work cr Kai 235 front 255 rear
INTERIOR & AUDIO
CF dipped dash
Carbon gear stick
Razo pedals
genuine nissan floor mats
Greddy Boost guage with greddy pillar mount POD (has memory setting, electronic style)
Greddy full automatic turbo timer (all features) black
Clarion VRX766VD DVD/MP3/CD Touchscreen 7" Single DIN TV.
Clarion CCA673700 ipod Video Cable)
Cadence 3 way 6x9's rear
Cadence 4 way 6" fronts
Pioneer GM-6100F 600W 4 channel amp
Pioneer 305CBOX2 12” sub
New betttery
Mongoose M80 alram/immobiliser with window lifting module
15% tints by eagle tints/alarms
Satellite tracking
ENGINE MODS
Greddy FMIC 600x300x80
Custom 3” exhaust <90dB
Custom dump pipe to suit GT30R turbo
New Garrett GT30R low mounted turbo
1 bar actuator
Greddy oil catch can
all braided oil lines
Apexi Power FC computer
Eboost 2 electronic boost controller
Z32 AFM
blue silicone intake piping
Sard 550cc Fuel injectors
Sard Fully adjustable rising rate fuel pressure regulator
New Iridium plugs (under 1000km old)
Splitfire Coilpacks
500hp fuel pump
Greddy Type S BOV
Custom air box
Apexi air filter
Exedy 4puk brass button clutch 2000 kms old
Also comes with spare kakimoto exhaust (lovely note, although removed during engineering process)
SUSPENSION & BRAKES
Cusco front and rear strut braces
Tein height and damper adjustable coilovers
Fully adjustable castor rods
upgraded DBA4000s front disc rotors with ferodo pads
upgraded RDA performance rear rotors with bendix advance pads
(all calipers are sprayed red with the silver nissan logo)
It made a safe 260RWKW tuned by MRC at Castle Hill on 18psi. This was acheive with low timing too. If i get around to it i will have it re-run with some more timing
235RWKW on 13psi.
The car is serviced every 5000km without fail and has nothing but elf excellium fully synthetic oil , diff and gear box oils are royal purple.
The previous owner spent a lot of money modifying this car and i've spent $12,000 (receipts to prove) in the last year alone.
No rush to sell at this time
I'm after $19,000 but will take parts off to lower the price.
I am contactable via pm or by 0421866768
Cheers Greg
No test pilots or time wasters please
PICS
https://www.sau.com.au/forums/topic/237128-white-r33-s2-260rwkw/
  • 4 weeks later...
  • 4 weeks later...
Wow Greg thats a good price for your car mate.
Hmmm, lets me get this right, i just sold my 97 model just a couple of days ago for $15200 and it only had 177.8rwkw. You guys can get the same quality car with 82.2rwkw more for an extra $1300, thats gotta be the cheapest 80+ killer wasps you can get!!!! Great car for the price and good luck with the sale mate!! Free bump for a hot arse 33!!!
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
