Sau Stickers
DamageInc
 Share
  • Replies 160
here is the pics i took....it was one of the easiest stickers ive ever put on which was ace and it looks mad.
i hope you can see the sticker enough in the last one....bad lighting outside
sorry for the missiveness of the pics
look out for me on the streets
yea but when my rear window got smashed...and we removed the rear window wiper assembly it was all rusted and couldnt put it back in..so im on the search for another one....or not..i like it without
yeah Carl love the PC
those photo's you sent me didnt inspire me to come up with a new signature sorry
maybe take Charmaine for a drive and see if she can take a really nice shot of your car :D;)
I would like one, but just the (skylinesaustralia.com) one
Not really keen on the GTR badge style SAU sticker
So, would it be possible to get a hold on one of those stickers?
I'm in adelaide aswell 5108, Price?
Thanks mate
if i decide to put just the SAU on my pc case you can have the url bit for say $3 ?
Cheers Mitch, they look awsome.
GreaT performance part, may increase power by 10kws (with enthusiastic driving)
LOL, thanks mate
i found that the 3m material used gave me 15kw at all wheels , get your car dyno'd and post results :cheers:
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
