On Skool Holidays? Bored? Me Too...
Such a beautiful story *sniff*
I remember I was hammering on a fence in the backyard when my dad approached me. He was carrying a letter or something in his hand, and he looked worried. I continued to hammer as he came toward me. "Son," he said, "why are you hammering on that fence? It already has plenty of nails in it." "Oh, I'm not using nails," I replied. "I'm just hammering." With that, I returned to my hammering. Dad asked me to stop hammering, as he had some news. I did stop hammering, but first I got a couple more hammers in, and this seemed to make Dad mad. "I said, stop hammering!" he yelled. I think he felt bad for yelling at me, especially since it looked like he had bad news. "Look," he said, "you can hammer later, but first--" Well, I didn't even wait to hear the rest. As soon as I heard "You can hammer," that's what I started doing. Hammering away, happy as an old hammer hog. Dad tried to physically stop me from hammering by inserting a small log of some sort between my hammer and the fence. But I just kept on hammering, 'cause that's the way I am when I get that hammer going. Then, he just grabbed my arm and and made me stop. "I'm afraid I have some news for you," he said. I swear, what I did next was not hammering. I was just letting the hammer swing lazily at arm's length, and maybe it tapped the fence once or twice, but that's all. That apparently didn't make any difference whatsoever to Dad, because he just grabbed my hammer out of my hand and flung it across the field. And when I saw my hammer flying helplessly through the air like that I just couldn't take it. I burst out crying, I admit it. And I ran to the house, as fast as my legs could take me. "Son, come back!" yelled Dad. "What about your hammer?!" But I could not have cared less about hammering at that point. I ran into the house and flung myself onto my bed, pounding the bed with my fists. I pounded and pounded, until finally, behind me, I heard a voice. "As long as you're pounding, why not use this?" I turned, and it was Dad, holding a brand-new solid-gold hammer. I quickly wiped the tears from my eyes and ran to Dad's outstretched arms. But suddenly, he jumped out of the way, and I went sailing through the second-story window behind him. Whenever I hear about a kid getting in trouble with the drugs, I like to tell them this story.
  • Replies 49
:D I can't believe how I read through all that. hahaha
Uni holidays, so much studying to do. So hard to even start studying, but when you do, you only go for 5mins then go do something else... :(
To take the whole spud/tennis ball gun a bit further, we always found it fun to play tennis ball gun cricket. You need a slightly longer pitch but you'll work that out!
ROFL dude haha i never thought of that haha, with my one ud have to be at least 400 meters away before id even stand in fornt of it haha
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
