On Skool Holidays? Bored? Me Too...
Such a beautiful story *sniff*
I remember I was hammering on a fence in the backyard when my dad approached me. He was carrying a letter or something in his hand, and he looked worried. I continued to hammer as he came toward me. "Son," he said, "why are you hammering on that fence? It already has plenty of nails in it." "Oh, I'm not using nails," I replied. "I'm just hammering." With that, I returned to my hammering. Dad asked me to stop hammering, as he had some news. I did stop hammering, but first I got a couple more hammers in, and this seemed to make Dad mad. "I said, stop hammering!" he yelled. I think he felt bad for yelling at me, especially since it looked like he had bad news. "Look," he said, "you can hammer later, but first--" Well, I didn't even wait to hear the rest. As soon as I heard "You can hammer," that's what I started doing. Hammering away, happy as an old hammer hog. Dad tried to physically stop me from hammering by inserting a small log of some sort between my hammer and the fence. But I just kept on hammering, 'cause that's the way I am when I get that hammer going. Then, he just grabbed my arm and and made me stop. "I'm afraid I have some news for you," he said. I swear, what I did next was not hammering. I was just letting the hammer swing lazily at arm's length, and maybe it tapped the fence once or twice, but that's all. That apparently didn't make any difference whatsoever to Dad, because he just grabbed my hammer out of my hand and flung it across the field. And when I saw my hammer flying helplessly through the air like that I just couldn't take it. I burst out crying, I admit it. And I ran to the house, as fast as my legs could take me. "Son, come back!" yelled Dad. "What about your hammer?!" But I could not have cared less about hammering at that point. I ran into the house and flung myself onto my bed, pounding the bed with my fists. I pounded and pounded, until finally, behind me, I heard a voice. "As long as you're pounding, why not use this?" I turned, and it was Dad, holding a brand-new solid-gold hammer. I quickly wiped the tears from my eyes and ran to Dad's outstretched arms. But suddenly, he jumped out of the way, and I went sailing through the second-story window behind him. Whenever I hear about a kid getting in trouble with the drugs, I like to tell them this story.
  • Replies 49
:D I can't believe how I read through all that. hahaha
Uni holidays, so much studying to do. So hard to even start studying, but when you do, you only go for 5mins then go do something else... :(
To take the whole spud/tennis ball gun a bit further, we always found it fun to play tennis ball gun cricket. You need a slightly longer pitch but you'll work that out!
ROFL dude haha i never thought of that haha, with my one ud have to be at least 400 meters away before id even stand in fornt of it haha
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
