  • Replies 310
Posted Images
90% of people have opted to hold off on their original hoodie and wait for the new ones. Its fine if you want to receive your originals first. Ill be holding onto the blank hoodies until we are 100% with the new printing information and all of the costs has been organised. Thanks
https://www.sau.com.au/forums/topic/237131-hoodies/page/10/#findComment-4227636
Hi Damo,
I would like my original hoodie's sent first please.
I'm sorry if I have been a bit short, not intentional it's just I've been trying to follow whats going on with these for so long now and its hard to know whats happening.
So is everyone getting a blank hoodie sent out now too or is someone organinsing to have them printed/embroidered once they come in?
Cheers
Scotty, i posted your hoodies yesterday mate.
Cheers.
https://www.sau.com.au/forums/topic/237131-hoodies/page/10/#findComment-4234108
  • 3 weeks later...
Hehehe I have a nice black hoodie, I made two before I came back home, I have one and so does my bf. When people come to collect their shirts ill wear it to show you guys, will possibly make a batch next year for winter.
https://www.sau.com.au/forums/topic/237131-hoodies/page/10/#findComment-4273947
Just throwing it out there, on these next hoodies I know we can't change our order, but was wondering if anyone that ordered an XL and wanted a L, as I got a L and need an XL.
Was hoping when we get the new ones printed I could swap my Large black hoodie with no name for someone's Extra Large black hoodie with no name.
Greatly appreciated if anyone could, thanks.
https://www.sau.com.au/forums/topic/237131-hoodies/page/10/#findComment-4278491
i emailed Ben tracking down exactly where they are, he assumed they had been sent as it had been so long, so he followed up. Splash Alley had stock issues again, and they should be ready for shipping today.
https://www.sau.com.au/forums/topic/237131-hoodies/page/10/#findComment-4293778
Blanks arrived the other day, just waiting to hear more information about who is going to print these new ones...
Tony, do you want the old ones posted to you? Im happy to do that tomorrow for you.
https://www.sau.com.au/forums/topic/237131-hoodies/page/10/#findComment-4319802
HEY !!! what the hell is going on with these things?
Have you fallen asleep? Is there a coma I'm unaware of?
With all the patience and compassion everyone has displayed throughout this ridiculous ordeal, you'd think there'd be some solid effort put in to get this sorted.
I think someone along the way joked about getting them by xmas. Well would you look at that?
https://www.sau.com.au/forums/topic/237131-hoodies/page/10/#findComment-4319798
I do Eddy. ill be at Vilis on Friday night to hand out the old hoodies, can i strongly encourage those who have not picked them up to come and grab them. Thanks. Ill be there from about 8:00.
https://www.sau.com.au/forums/topic/237131-hoodies/page/10/#findComment-4319845
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
