Blanks arrived the other day, just waiting to hear more information about who is going to print these new ones...
Tony, do you want the old ones posted to you? Im happy to do that tomorrow for you.
that would mean posting twice = added hassle. so i'll wait for both. just hoping that doesnt take forever.
https://www.sau.com.au/forums/topic/237131-hoodies/page/11/#findComment-4319867
  • Replies 310
Posted Images
hey guys, unfortunately i wont be able to make it to Vilis tonight. If anyone wants theirs desperately, im happy to post, or you can pick them up from town next week. I should be at the Olds appreciation cruise as well. Thanks
https://www.sau.com.au/forums/topic/237131-hoodies/page/11/#findComment-4327165
So many things have happened since the inception of this group buy... is there still someone trying to get new ones made up or has the whole thing just been dropped? I know fishpaste said he was getting some quotes, did that lead anywhere?
https://www.sau.com.au/forums/topic/237131-hoodies/page/11/#findComment-4342959
We need someone to take over and try to get these printed properly. I'm in no hurry as mine doesn't fit too well, gotta have the sleeves up whenever I wear it, bit short.
Still waiting for someone to swap me (when we get the new ones) my Large unnamed hoddies for an extra large unnamed hoodie. Any takers?
https://www.sau.com.au/forums/topic/237131-hoodies/page/11/#findComment-4344191
  • 1 month later...
any updates? I am quite happy at this stage to be giving people their original and blank ones.
Graham and Tha, hoodies have been posted. Apologies for the delay
Tony, just checked pm, Adrian will post yours this week.
Thanks
https://www.sau.com.au/forums/topic/237131-hoodies/page/11/#findComment-4404519
Final pricing on the new printing will be defined by the end of the week. Fishpaste has narrowed the search down to 3 printers.
So, you can either:
Collect your original and blank from us (me/Adrian) on Friday 7:30 at Vilis.
or
Collect your original and i will give the remaining blanks to Fishpaste. Then he will compile a list of who wants printing.
interstate people i will obviously post to, let me know which option you would like.
HI2U, i would prefer to post the item you paid for, as i am not a shop/trader, therefore returns would come out of my own pocket.
So, hoodies can be collected for (i hope for everyones sake) the final time on Friday: Cafe De Vilis, 730pm.
https://www.sau.com.au/forums/topic/237131-hoodies/page/11/#findComment-4404592
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
