  • Replies 310
Posted Images
Yay activity. Umm HI2U, your hoody isn't an XL by any chance is it?
And since we're changing the design (we'll, handing in a design) does this give people the opportunity to remove their names? I'd really like an unnamed XL in the new design if anyone is willing to swap for my L unnamed.
Oh and it may have been 6 ish months but looks like we're getting somewhere haha. Thanks guys.
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4405147
lets do this design on our blank ones!
lol Kietz when you're not being a smartass you're actually quite a valuable contributor to SAU....good job.
As I said awhile ago, that's clearly the best design I've seen so far for a hoodie.
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406499
hey damo. i sent u a pm a couple of weeks ago about sending my hoodies as they are.
cbf waiting for printing, and possibly more dramas. just send both. cheers man
edit:
d'oh :D
Tony, just checked pm, Adrian will post yours this week.
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406537
i agree with ya pete
but i was just saying that we dont want another club going around saying that we copied their idea/design
im sure they wouldnt mind, i think whoever wants the design put their hands up and we get the printing organised before it hits winter! and whoever doesnt than they can just drool when we get ours :D
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406684
Count me in then
i was just trying to be on the safe side kietz
not trying to play it down or anything mate
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406689
i rly like that design too kietz, its fkn awesome :D
i dont mind if its similar to another clubs design.
im on lates this week, so i wont be able to get mine. If there is someone that lives in the brighton/seacliff area that can grab mine that would be sweet ;)
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406756
gtrkiet's design idea looks great imo, i'd be happy to get that.
And who cares if its similar to another clubs design, they'd have boring hondas on theirs and ours will have the awesomeness of the Skyline, so ours would be better :D
https://www.sau.com.au/forums/topic/237131-hoodies/page/12/#findComment-4406964
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
