DRD-OOF
Let me see, for being a smartass, for being OT, for whoring a thread after a warning......have another 20% warning to go with the existing ones that Slim & Evil Weevil gave you for similar stunts.
Imagine if everyone was as clever as you, there'd be approx 2 or 3 posts max per page.....don't say you weren't warned.
https://www.sau.com.au/forums/topic/237131-hoodies/page/16/#findComment-4510089
  • Replies 310
Posted Images
f**k there are some f**king ungrateful pieces of shit on this website. You got two hoodies for $50. Mine is fine, good for $50. I don't really know what you were expecting? Hugo Boss or something? f**k. Say thankyou Adrian for all the effort you have put in and thankyou Adrian for putting your time into organising and posting them to me and thankyou Adrian for chasing it up when something went wrong.
https://www.sau.com.au/forums/topic/237131-hoodies/page/16/#findComment-4510120
i dunno, there is some good info in here about picking up or organising postage (hint hint, still got heaps of them). I guess you can lock it, and all questions about pick-up/postage can be directed to either myself or Adrian. I guess when Fishpaste organises those who want reprints done, a new thread can be used.
https://www.sau.com.au/forums/topic/237131-hoodies/page/16/#findComment-4511065
Hey guys, I still don't have mine and have not been advised if posted or not..
please let me know.
I have been appreciative and patient but now I feel i am being ignored.
On Monday 2nd March Rad32 said will be posted thurs or friday but I have not had confirmation they are on the way and not received them.
On 24th march I sent PM asking and had no reply.
so, Adrian, are they on their way? (Sklyn & Msquito)
I do appreciate all your effort guys and thankyou, but I would like to receive something.
cheers.
https://www.sau.com.au/forums/topic/237131-hoodies/page/16/#findComment-4511273
DRD-OOF
too serious for me, I'm out :sick:
Thanks for the memories.
edit: actually, what's OT?
https://www.sau.com.au/forums/topic/237131-hoodies/page/16/#findComment-4511306
Kel we have had blanks for quite a long time now, Fishpaste has kindly offered to organise reprinting. Myself and Adrian, however, will have nothing to do with the reprints other than distributing the blanks.
https://www.sau.com.au/forums/topic/237131-hoodies/page/16/#findComment-4511408
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
