  • Replies 310
Posted Images
on the plus side we get the extra dodge 1 aswell, which can come in handy for bumming around the home n working on the car n such :banana:
its not that much extra n on the plus side i dont think he made cash off us which makes me happy :P
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4149179
its not that much extra n on the plus side i dont think he made cash off us which makes me happy :banana:
you would be surprised at how much those hoodies actually cost that's why its easier for him to just replace the stuffed up one and walk away from the whole situation and for him there is 2 positives out of this situation
1) we respect him as a businessman and probably wouldn't talk any further about his business (remember he doesn't do the printing)
2) he still makes a small amount off us just the profit margin is significantly reduced and i assume the printers would have to forfeit some of there profit too for making errors also
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4149287
is it gonna be a print or embroidery?
dont be put off by the dodgey printing we've seen recently. a good print looks much better than embroidery imo. more detail. smooth finish. not lumpy, and doesnt distort the flow of the fabric.
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4149444
Considering the situation, this is a very positive outcome. Well done to all involved. I look forward to getting both hoodies and the new one having a much improved finished design.
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4150783
pretty good outcome i guesss.
two hoodies for $56 is pretty good for me.
specially since i earn less than that in a week being a full time year12 student yewwww. schools almost finished :)
will keep an eye on this for Madaz's quotes on new printing on new hoodies....
just a question...our new hoodie, do we get it the same colour as the first one we ordered?
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4151101
can we get the 1st crappy hoodie sent out and then pay the extra 20-30 bucks when the time comes??
+1 for that question
Or do we have to wait for the new embroidery on the freebie blanks?
Oh yeah and thanks Adrian + Damo & anyone else involved for sorting out the mess!
Can whoever sorts out the new hoodies send a PM when the time comes because its hard for me to keep finding the threads on these things
https://www.sau.com.au/forums/topic/237131-hoodies/page/2/#findComment-4151183
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
