  • Replies 310
Posted Images
Good outcome, I await the next step :P
I think it's probably a good idea to send out the shonkey jackets as we have already paid for delivery on those, would be easier then paying a bit more and mixing up the money left right and centre...
https://www.sau.com.au/forums/topic/237131-hoodies/page/3/#findComment-4151696
I think this is a pretty damn good outcome, thanks a lot guys, very happy with it!
In my opinion I think we should try to get the blotched hoodies out first and maybe if we pick them up, we can pay for the new printing while collecting the blotched ones?
Whatever is easiest to organize I suppose.
If the blotched hoodies are being handed out this friday night, what time will you guys be there till? Do we need any I.D as to who we are?
https://www.sau.com.au/forums/topic/237131-hoodies/page/3/#findComment-4151755
I must make mention that Ben from Velflex provided me with excellent customer service! I also would like to thank everyone for their patience, and again i apologise for not getting us the hoodies we wanted, but myself and Adrian have negotiated the best possible outcome for us.
https://www.sau.com.au/forums/topic/237131-hoodies/page/3/#findComment-4158213
good job guys
i will get the quote for new printing on monday, we will need a mix printed logo and url and embroidered username
printing would be a silk screen except its not silk they use any more :cool: and he is doing quote's for complete supply and print for another batch
https://www.sau.com.au/forums/topic/237131-hoodies/page/3/#findComment-4158461
i rekon, like discussed in the wasteland thread that we should get the generations of skyline like the prelude club, 32, 33, 34, prob leave 35 outta it, but dunno! i rekon thats the best design so far, of course with the sau on it! thoughts?
https://www.sau.com.au/forums/topic/237131-hoodies/page/3/#findComment-4159244
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
