  • Replies 310
Posted Images
I'll wait for the new hoodie to be printed, and have them both sent together. Less stuffing around, and i dont think i'll need warm clothes for a while now :nyaanyaa:
Cheers guys. Will check back to see whats going on with the printing fees, etc.
Someone hit me with a PM if need be :banana:
https://www.sau.com.au/forums/topic/237131-hoodies/page/5/#findComment-4164102
Yeah sure Carl, dunno when I'll get it though but at the latest it'll be monday on Damo's cruise.
Might see what I'm doing tomorrow before work, could you PM me your phone number so I can call before and make sure you're home.
Tom.
https://www.sau.com.au/forums/topic/237131-hoodies/page/5/#findComment-4171119
Tom.
PM sent
btw i used to work at brighton foodies
FOODIES FTMFW
https://www.sau.com.au/forums/topic/237131-hoodies/page/5/#findComment-4171640
ok guys i have a new quote for screen printing and we will have to do a print/embriod to get the cheapest job
Print SAU logo and URL on the back and embroid our user names
now i know some people have spoken too me saying they want embroidery (well only 2) but personally i dont want to spend another $20+ on getting that done
i think a print/embriod should cost no more than $15 (to which i still dont want to pay :))
obviously will be cheaper the shorter your username i just need to get a price per character on embroidery but printing will cost $9.10 per jumper
https://www.sau.com.au/forums/topic/237131-hoodies/page/5/#findComment-4186731
Good work Steve.
So in my case, no username, means a total of $9.10. correct?
PM me about payment, along with your details etc.
cheers :)
Edit: So do you have our jumpers now?
Edited by Munkyb0y
https://www.sau.com.au/forums/topic/237131-hoodies/page/5/#findComment-4186771
Sounds good to me aswell, will obviously be a little extra for my username but still sounds good :P
I think possibly once you get details on price for letters on usernames, start new topic for YOUR hoodies steve?
https://www.sau.com.au/forums/topic/237131-hoodies/page/5/#findComment-4186930
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
