I have a r33 gts-t but with a rb26/30 engine in it, she has full forged internals - Arias pistons, Arias Rods, Full Tomei Gasket kit, upgraded cams...lets just say she is a weapon but he thing is its got standard turbos on it, im wondering if anyone out there could tell me whether to go back to a single turbo formation or keep the twin setup, also what type of turbos to use...im looking for big hp out of this engine as its built for it...
thanks every1 :)
https://www.sau.com.au/forums/topic/237148-rb2630/
Been looking at this lately aswell, as im leaning towards a home built RB26/30 instead of a straight Rb26
Lost of guys in the UK have done alot of research and testing on turbos for 3.0l RBs (one dude has tried like 5 different turbo setups...cash to burn) and there is loads of info on both the SAU RB30 dyno sticky and on the UK GTR forum.
But from what ive gathered in my research lately, ill give you sorta both ends of the power spectrums for both setups...
Most of the local boys seem to like using singles, with a GT30R as a minimum (350+rwkw) and serious cars use hardware like GT42Rs and T51Rs (600+rwkw).
But twins could still be an option. Garrett -5s are probably the minimum and i think would spool nice and quickly (350+rwkw) and on the other end the scale a highmount pair of Garrett GT3071s would make for a wild ride (600+rwkw).
You need to set some firm goals, both for power and responsiveness. What will the car be used for etc. And then use all the resources to work out what the best setup will be for you.
Hope that gets you started
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149100
A few people on here run GT3076R turbos in the .82 AR rears they are making good boost around 3000rpm and top out at 300-320kw, then there is the GT3582R, in .82 AR rear this turbo is capable of ~350-370kw and is on good boost levels around 3500rpm and with the 1.06 AR rear is good for a bit over 400kw with good boost levels around the 4000rpm mark. (by good boost levels i mean 1 bar or more)
i personally haven't looked into the twin setups much so cant really comment on them but the Veilside R32 drag car runs twin GT3582R's so if 1400hp is your goal that's a possibility :banana:
Edited by TiTAN
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149157
if your sticking with the stock manifolds get twin
else single high mount
as said above set some power/response/cars purpose goals
twin you need 2 of everything so it will cost more, unless you get soemthing like a GT-RS twin setup on stock manifolds
then you can utilise most of the existing hardware
high mount single ftw.....
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149256
Turbonetics GTK series gets my vote... either the 650 / 800. Just came out from a build with one of these and we are most impressed with the results. Compared to the Garrett items; cheaper, better build quality, and better performance IMO.
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149481
GT35R
T04Z
T51R
Twin GT-RS's
Twin 2540's
Twin -5's
Twin -10's
Since the day i drove my 3L ive wanted to have a go of a built 2630 with something like r34 n1's or 2530's just to see how much fun that can be in the hills
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4159895
I don't think it's going to be a very fair comment from me as I do run an auto transmission with a high-stall convertor. Car is still at the tuners (awaiting new flex plate) so all I can go off is the initial graphs.
14 psi is reached at 4,200rpm...
I'll post up more info next week after the tuning is finished, as I believe this result can be improved by tweaking the E-01, so far only the F-CON has been tuned and not the EBC.
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4169086
GT35R
T04Z
T51R
Twin GT-RS's
Twin 2540's
Twin -5's
Twin -10's
A mate has these on his 30, makes 540whp @ 1.3bar!
I've got a GT35R w/ .82 housing to go on my 30 :cool:
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4169770
hurry up and get it on there already bubba :)
Soon! plenum should be ready very shortly, spoke to the fabricator on Tuesday, all the prep work was done and he was about to start welding!
Got a graph for the 2540's?
What else is done to it - cams, headwork etc?
I bet its a fkn rocket
No graph handy, it's a 25t head (no porting or anything), 272 cams I think, greddy plenum, q45 t/b.. and it's in a 4wd platform.. yes, it's a fkn rocket :D
I have a clip of it's first night out.. pm me if you want to check it out ;)
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4172400
Not sure what to do with my exhaust.. was thinking 3" dump off the turbo, then join the gate pipe in where the front pump turns horizontal and flare to 3.5".. or should I be going bigger straight off the turbo?
Edited by bubba
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4172480
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
