I have a r33 gts-t but with a rb26/30 engine in it, she has full forged internals - Arias pistons, Arias Rods, Full Tomei Gasket kit, upgraded cams...lets just say she is a weapon but he thing is its got standard turbos on it, im wondering if anyone out there could tell me whether to go back to a single turbo formation or keep the twin setup, also what type of turbos to use...im looking for big hp out of this engine as its built for it...
thanks every1 :)
https://www.sau.com.au/forums/topic/237148-rb2630/
Been looking at this lately aswell, as im leaning towards a home built RB26/30 instead of a straight Rb26
Lost of guys in the UK have done alot of research and testing on turbos for 3.0l RBs (one dude has tried like 5 different turbo setups...cash to burn) and there is loads of info on both the SAU RB30 dyno sticky and on the UK GTR forum.
But from what ive gathered in my research lately, ill give you sorta both ends of the power spectrums for both setups...
Most of the local boys seem to like using singles, with a GT30R as a minimum (350+rwkw) and serious cars use hardware like GT42Rs and T51Rs (600+rwkw).
But twins could still be an option. Garrett -5s are probably the minimum and i think would spool nice and quickly (350+rwkw) and on the other end the scale a highmount pair of Garrett GT3071s would make for a wild ride (600+rwkw).
You need to set some firm goals, both for power and responsiveness. What will the car be used for etc. And then use all the resources to work out what the best setup will be for you.
Hope that gets you started
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149100
A few people on here run GT3076R turbos in the .82 AR rears they are making good boost around 3000rpm and top out at 300-320kw, then there is the GT3582R, in .82 AR rear this turbo is capable of ~350-370kw and is on good boost levels around 3500rpm and with the 1.06 AR rear is good for a bit over 400kw with good boost levels around the 4000rpm mark. (by good boost levels i mean 1 bar or more)
i personally haven't looked into the twin setups much so cant really comment on them but the Veilside R32 drag car runs twin GT3582R's so if 1400hp is your goal that's a possibility :banana:
Edited by TiTAN
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149157
if your sticking with the stock manifolds get twin
else single high mount
as said above set some power/response/cars purpose goals
twin you need 2 of everything so it will cost more, unless you get soemthing like a GT-RS twin setup on stock manifolds
then you can utilise most of the existing hardware
high mount single ftw.....
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149256
Turbonetics GTK series gets my vote... either the 650 / 800. Just came out from a build with one of these and we are most impressed with the results. Compared to the Garrett items; cheaper, better build quality, and better performance IMO.
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4149481
GT35R
T04Z
T51R
Twin GT-RS's
Twin 2540's
Twin -5's
Twin -10's
Since the day i drove my 3L ive wanted to have a go of a built 2630 with something like r34 n1's or 2530's just to see how much fun that can be in the hills
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4159895
I don't think it's going to be a very fair comment from me as I do run an auto transmission with a high-stall convertor. Car is still at the tuners (awaiting new flex plate) so all I can go off is the initial graphs.
14 psi is reached at 4,200rpm...
I'll post up more info next week after the tuning is finished, as I believe this result can be improved by tweaking the E-01, so far only the F-CON has been tuned and not the EBC.
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4169086
GT35R
T04Z
T51R
Twin GT-RS's
Twin 2540's
Twin -5's
Twin -10's
A mate has these on his 30, makes 540whp @ 1.3bar!
I've got a GT35R w/ .82 housing to go on my 30 :cool:
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4169770
hurry up and get it on there already bubba :)
Soon! plenum should be ready very shortly, spoke to the fabricator on Tuesday, all the prep work was done and he was about to start welding!
Got a graph for the 2540's?
What else is done to it - cams, headwork etc?
I bet its a fkn rocket
No graph handy, it's a 25t head (no porting or anything), 272 cams I think, greddy plenum, q45 t/b.. and it's in a 4wd platform.. yes, it's a fkn rocket :D
I have a clip of it's first night out.. pm me if you want to check it out ;)
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4172400
Not sure what to do with my exhaust.. was thinking 3" dump off the turbo, then join the gate pipe in where the front pump turns horizontal and flare to 3.5".. or should I be going bigger straight off the turbo?
Edited by bubba
https://www.sau.com.au/forums/topic/237148-rb2630/#findComment-4172480
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
