thanks every1 so far with comments, ive been really interested in either the t51r bb Kai or SPL, or t88....single setup tho, but i wouldnt mind keeping the twin setup :), i want to make big hp so keep them coming guys.., i wouldnt mind looking at the twin setup that TiTan come up with "Veilside R32 drag car runs twin GT3582R's"
everything is costly so i might as well go best then cheap!!!
thanks guys
Edited by 74nky
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4175719
rb26/30 forged rods
pistons, acl bearings, n1 oil/water pumps, arp bolts everywhere. gt4094r single,4"dump.
run 2.5bar boost max 1.5bar by 3600rpm.full boost 4200.
superb turbo for road/track, responsive yet makes the numbers.
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4190710
rb26/30 forged rods
very impressive. do u have a dyno sheet u can post ?
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4192188
his post from the dyno thread
did some dyno work yesterday.lol
p.s. figures are bhp @ the flywheel.
well some of you know the car by now, and as i have have fitted a new turbo it was time for a tweek on the map..
still got some misfire issues and could only run 1.9 bar boost, but heres, the graph.
spec is.
rb30 block fully prepped with spool rods and cp forged pistons
n1 oil/water pumps,
jun stage one cams 264/272 9.7mm lift
1000ccs injectors,
twin in-tank tomei pumps feeding both ends of the rail, 8mm return to tank fitted.
gt4094r turbo, 50mm turbosmart gate, 4" downpipe.
plus usual bits lol.
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4192285
sory to hijack
just on this topic im looking for a turbo a bit bigger than a 3582R but dont want to loose too much response due to car being used for drift.
have a rb30/26, forged pistons, rods, cams, high mount mani, greddy plenum, 100cc injectors and all the usual bits and pieces.
should i just go the bigger rear housing (1.06) or what is the next size turbo up?
cheers
Mitch
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4192483
rockabilly - whats with the big midrange dip? Your loosing massive mid-range poke from 4700-5800
The line should continue building, and not drop off and resurge
Oh, and if anyone needs a T88 (saw it mentioned earlier) i know of a kit for sale. PM me if interested
https://www.sau.com.au/forums/topic/237148-rb2630/page/2/#findComment-4194618
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
