Hi guys. I'd like to hear input on the following ------I recently installed a mines tuned non programmable ecu, it got rid of r&r holding ign at about 17* tru the revs at wot on the apexi multichecker. The prob is it pings off boost at low rpm in higher gears showin up to 50* on the multichecker. I retarded the timin via the cas to see if this would make a difference but..... it did'nt Dont matter how much i retard it still shows 15* on idle and it made the car lazy going to about the same readin as before AN IT STILL PINGS!!!!!!
Should'nt adjusting the cas affect the timing somehow?
Also i tried to richen it up in that area with an safc2 -it retarded it by one or two degrees but IT STILL PINGS!!!!!
Any suggestions?
Oh.....with the stock ecu max ign at the same load is about 40* an goes to 8* when it hits r&r at wot RB25det s1 10psi
https://www.sau.com.au/forums/topic/237200-adj-cas-no-change-on-multichecker/
If this "multichecker" is simply pulling a timing figure from the ecu then it won't show any difference due to moving the cas. The ecu assumes 15deg base timing is set and everything is relative to that. As for why it's pinging off boost at low rpm in high gears... I'd be taking it to a pro quicksmart!
you are using 2 bandaid solutions and 1 monitor only device
throw all of your devices in the bin and buy a real ecu
failing that, if you insist on keeping it, get rid of the mines ecu and use stock ecu
then get the safc tuned properly.
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
