Car - 1974 Datsun 260z Fairlady
Mileage - 43,520km
Suspension - 50mm Bilstein Coilovers (heismans worth $4300)
- Konig dish rims with Bridgestone Potenza GIII's
($1,600)
- All suspension bushings replaced to give it very precise handling.
Body - Resprayed CRV `07-spec silver 3 months ago ($3500). Exterior was stripped back to metal.
Motor - Used rebuilt L-series motor with mild cam.
-Stard SU carbs.
-Full exhaust system including Stewart Wilkins headers
Interior - Very clean for car this age. All original.
Weld in CAMS approved half cage (no engineering required as it's a two seater). And old car with thin A-pillar really does need this for safety.
Carsales add - http://www.carsales.com.au/used-cars/priva...395&trecs=6
Price $14,500neg
General Comments: Car is super clean and reliable. Have had all service parts replaced i.e wheel bearings, gaskets, window seals, oils.....etc
Contact Details - William 0434207174
Call after 5pm or msg me here.
https://www.sau.com.au/forums/topic/237206-fs-syd-rare-260z-fairlady/
Sick car man if i recall there was one just like this or this one for sale a while back almost a year ago i almost brought it man i love silver 260z's but i ended up buy a old one and im restoring it now seeing your car makes me want to do it silver sick car man looks hot as!
yeh man that was me and it's the same car. I had a buyer for $11K back then but I pulled out the last minute.
since then it's had a new paint job and another motor and it's fresher than before hence prices has gone up.
G'luck with yours.............their quite addictive.
  • 3 weeks later...
Dunno, but my mate just checked through the for sale lists and japan and the last one was sold for 6mill yen :rant:
hahahhaha $85K?
um mines not that perfect.........though if i knew i can get that sort of price I can get it 'that' perfect.............hehehhee.
Should've checked before you sold it :D Whoever bought it has a nugget!
wasn't even in the relms of possibilities for me...............still quite content with the price it sold.
only regret is the driving experience these things give when their well sorted.
I've seen what comes out of jp and their all 100% original...........my one is far from it.
thanks for the tip though..........as I'm sure i'll buy another in the future.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
