Hey guys, My Climate Control on the R34 stopped Illuminating itself. Im guessing that the bulb inside has decided to take a break lol.
Any info i can get on changing it ? Because it makes it a hell-a-lot hard to navigate when im driving at night and try to use the Air Con etc etc.
I only just noticed it last night lol! When the hazard button wasnt illuminated.
Cheers in advanced !!
MRXTCZ
P.S I think 666DAN has some gear to sell, but i dont know how to install it.
https://www.sau.com.au/forums/topic/237207-r34-climate-control-panel/
1. pop off your aircon vents (using flat head screwdriver and a cloth)
2. take out ashtray and undo the screw under it
3. pop off your gear surround (using flat head and cloth near handbrake)
4. under four screws (two top, two bottom, to remove the entire center console including climate control panel)
5. take off the four screws (some only have two) holding the climate control panel together.
6. disconnect the two plugs connecting the climate control panel.
7. you'll notice that there are several 'levers' to open climate control panel itself... i use a guitar pick (or three) to open without breaking any levers.
8. you'll find three twist type bulb holders. twist them to remove.
9. insert new bulbs (t10 i think, not sure though). Or make some new led ones up, by pushing the legs through the two little holes in the bulb holder.
10. check to see if they light up. when it's all back together.
reverse process to install again.
Hope that helps.
Cheers man that was great!
Will try this arvo when i get back, need to get those T10 bulbs though, im guessing their the same for the Dash aswell.
You wouldnt know how to dismantle the dash to get to the bulbs would you :thumbsup: ?
MRXTCZ
Np's man. Dash are T5's I think... the climate control are smaller. Although you can modify the T5 led's dan sells to fit the climate control panel by bending out the legs and sticking them in.
To dismantle the dash..
1. remove the bezel around the dash cluster.
2. unscrew the four screws (two top and two bottom i think).
3. drop the steering wheel to it's lowest point.
4. slowly pull towards the cluster towards you.
5. with your hands, reach in from behind and unclip the 3 or 4 looms connecting itself to the cluster.
6. with all looms disconnected from the cluster, try to pull left (in between the steering wheel) to remove.
7. replace all the appropriate bulbs (make sure they work, as led's have polarity).
reverse to reinstall.
  • 2 months later...
  • 9 months later...
my aircon button lights stopt working, i opended it up, seems they are blown, i took the bulb to autobarn, they said they dont sell them , where can i find them? are they t5 or t10
  • 4 months later...
  • 4 years later...
  • 4 weeks later...
  • 1 year later...
sorry to dig up an old thread. I am based out in the UK and have the same problem and would like to replace my blown bulbs but would like to install the original colour back in. Also i have tried to take the blue plastic cap off the blown bulb and have not been able to do this successfully as it seems the blue cap has been caked onto the bulb from continuous use and age. If someone knows the part number for the original part i would rather prefer that. Any help would be much appreciated. Thank you
Edited by bhp
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
    • I wouldn't be using the seats a lot since it's on Historic rego and will not be driven a lot, however I also don't want to fork out 3k for something that won't last. Havent looked at BRZ seats, aiming for something of the same era I did speak to him on the phone once, and I do see your point haha. How many kms do you think you drove before they started wearing out? Just had a look at yours, certainly looking for a reclinable version. The Brides don't look too bad! I would still like to sit in one just to make sure it's what I'm after.    Thanks for the replies fellas.
