Both the "grain of wheat" bulbs and silicon caps can be purchased easily off ebay, however its hard to see why you wouldnt go with white leds (SMD variety). They are brighter and more efficient.
In any case keep the plastic part of the lights. The bulb is only loosely wired into it, its the part that is meant to be replaced.
I had to retrofit LEDs into the original plastic mount to work
  • 4 years later...
I know this thread is over 10 years old now, but it's been useful for me, aside from the different sizes being suggested. The correct sizes are:
  • A/C panel buttons - 3x T4.2 (not T4.8 or T5!)
  • A/C panel LCD screen - 3x T3
Be aware that the T3s for the LCD screen are quite small in size, LEDs with large diffusers on them might not fit. The LCD screen bulbs can only be accessed by pulling apart the A/C panel unit itself, just a few tabs, but be careful not to break them.
96363736_746291905906663_5019285978255196160_n.jpg.caf1bb30d33edb4a2488d04ab422ea2b.jpg
Edited by oea
  • Like 1
  • Thanks 2
I got my illuminated nice and white.
here’s the eBay link to the bulbs I bought and put into the climate control
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F161839873383
they look like this And they use those leds(forgot what size they were though)
  • 4 years later...
Where did you get these bulbs from. Can’t find them anywhere.
