Make: Nissan
Model: 1990 HR32 GTS-T Skyline - rb20det
Milage: 72000 km's
Transmission: 5sp Manual
Colour: Wine Red
Complied? Yes
Currently registered? Yes - 04/09
Price: $12000
Contact: PM here or contact my mobile (Michael) - 0401 225 340
Well it's time to cut my expenses and the first thing to go is my much loved and babied Skyline - Next owner will NOT be dissapointed.
Since owning this car it has given me 0 problems, tough motor, no accident history, fresh clutch and gearbox and I have honestly never driven her hard - In fact she is mostly locked up in my garage for the weekend driving.
I purchased this car from an import dealer completely stock and as an automatic. I decided on an automatic on the advice of the dealer (personal friend) because after a long time of importing cars he came to the conclusion that automatics were generally kept in better nic in Japan. I then had his workshop convert it to manual using a conversion kit, and since has been trouble free.
Since my purchase I have kept up regular servicing and maintenance keeping it mechanically A1, whilst tastefully modifying her.
I have over $6000 worth of receipts from the work I have done on her (within the last 4 months) so my loss is definatly someone else's gain - But it's time I cut my losses.
Car is in immaculate condition with only 72,000kms on the clock. Serviced and looked after by Pro Concept, who have just completed a major service including:
- All fluids and oils (Motul)
- Filters (Oil and fuel)
- A complete inspection of the undercarriage, suspension and brakes (All fine bar the front brakes, which have been fixed)
- Throttle body cleaned
- New water pump fitted
- New timing belt and external drive belts fitted (Gates)
- New idle pulley fitted
Also....
- AFM replaced
- New front brake pads - Rotors machined
- New tyres (Maxxis 225/55/R17)
- New battery
Mod's include:
- 17" Rodney James racing rims
- Maxxis 225/55/R17 tyres
- X-force 3" Turbo back exhaust. Custom 3" dump pipe to stainless steel cat, to oval resonator, to 4.5" tip
- Blitz BOV
- K&N panel filter
- Blitz gearknob
- Whiteline front strut
- Just Jap FMIC (Currently not installed)
- Mongoose MX40 alarm system
- Dark window tints
- Sony head-deck + rear speakers
- Nismo seat covers
- HICAS lock bar
If anyone is looking for an impressive imported sports car that has been carefully looked after with potential for big power (up the boost, install the FMIC, tune the car) then this is the one for you - A great platform.
It's no secret that I baby my imported cars - This is my 3rd skyline and each one I have kept at a high standard.
All inspections welcome, and I'm more than happy to answer any questions or enquires relating to the car.
P.S feel free to PM me for more photos.
Cheers,
Michael
Edited by fragrelb
https://www.sau.com.au/forums/topic/237210-fs-1990-hr32-gts-t-skyline-rb20det/
  • 1 month later...
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
