<h1 class="big_one">Nissan GT-R Phantom by Amuse </h1>
nissan gt-r
Few months ago we were announcing that the Japanese tuner Amuse, broke the 600 hp barrier with the Nissan GT-R but without any extra information. Today, the technical information were revealed by the tuning house! With a new name, called the GT-R Phantom, the upgrade includes a new ECU software boosting the engine to an astonishing 611 hp at 6560 rpm and 775 Nm of torque.
nissan-gt-r-by-power-1_200x0w.jpg Due to the light materials used, the vehicle also loosed some weight, now it has only 1674 kg! The tuner also added a new exhaust system as well as a new adjustable suspension and standard brakes. At the exterior the GT-R Phantom received a carbon fiber front lip spoiler, new side sills and a carbon fiber rear wing spoiler. At the interior, everything remained the same, completed by the stylish Recaro sport seats. No words about the price yet!
https://www.sau.com.au/forums/topic/237231-602hp-amuse-gtr/#findComment-4152683
Very sad to hear of Power House Amuse founder and number 1 driver Hideki Tanabe-san's passing away last weekend. The R1 Phantom was the last car he worked on and is legendary already in these early stages of R35 GT-R tuning.
I remember seeing this car at TAS in January and being blown away by the quality of the parts he made.
Big loss.
Amuse will carry on with Tanabe-san's wife at the helm for now.
https://www.sau.com.au/forums/topic/237231-602hp-amuse-gtr/#findComment-4153810
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
