  • Replies 374
Ummm its a 26 dude......
So how did this thing go in Autosalon?
3 words
semis+dyno=fail.
customer left his semis on and it would not ride the rollers.... only spin....i was not there on sat to tell him to swap on some hard shitty tyres but offered to be there on sunday to tune it to suit the ramp rate only to be told not enough time.. very dissapointing.
Due to the ramp they were using most cars were off but those who took the time to quickly tune to the ramp rate did well.. darrens supra pulled well over 1100hp on sunday (to take out top spot, then they put the GAS car back on to beat it.... ) but pulled 700hp the day before... dwayne from hi-torque did a stellar job to bring it up to suit the dyno conditions.... if only we had a chance to do the same, im sure we would have pulled mid 900's based on sats results.
EPIC FAIL
these were the only words required.
I knew the car wouldn't run the numbers in real world testing under competition conditions.
Edited by DiRTgarage
Having seen what drag radials do on dyno rollers, I'd be kicking the owner in the arse for not swapping them for something hard and shitty.
X2. I couldnt crack 350 hp on semis then spun it out to over 500 with some hard streeters.
were people cleaning the rubber from their faces?
I remember watching the mighty BU5TER on the rollers at Powercruise at ECR and they turned to mush and sprayed everyone with melted rubber. It was spectacular but not great for big numbers.
LOL dont hold back paul, tell us what u really think
hehe... :)
Hey i call it like it is...it upsets people and rubs them up the wrong way on occasions but thats their problem.
He had his chance to prove all the naysayers wrong...and with all eyes on him he was foolish to not ensure the car was up to it.
I may have been too generous with my 800hp prediction. :(
Amatuers at their best. All that time effort and money for a dismal result. Oh well better luck next time.
And maybe Autosalon should notify all competitors on what ramp rate they're going to use so everyone can tune their car accordingly. What a load of crap. Take it to the track where the true results are revealed.
465.3 KW/624 HP :/
yeah something like that, same as the supra on saturday (bout 300rwkw short and 650-700hp on sat, then retuned on sunday pulled 1200hp).... all in the dyno operator.... it would have been easy to pull the right numbers with a bit of tuning to suit the way they were running....
Edited by URAS
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
