  • Replies 374
SO... is this still being used as a daily driver? Cause like... I don't go past any Sunoco outlets on the way to work...
*pokes flame*
come on its got so much torque he can tow a trailer around with a couple of 44 gallon drums of sunoco on board for refills every half hour... :dry:
Edited by unique1
as for the injectors it turns out they were most likely indy blues... but hey i have already been shot for guessing they were blitz 1000cc (also blue in color) .... them the brakes.
:dry:
If one of my kids ever asks me what an oxymoron is I think I'll use that as an example. :)
haha c'mon kiddies :thumbsup: 6000 with a 18cm is More responsive than 7000 with the 22cm option.....
they were blitz 1000cc (also blue in colour)
ahem...Blitz 1000cc are light green :thumbsup:
a lot more easier to swallow now the injectors are the correct size for the power output.
best of luck with the car at MAS.
Edited by DiRTgarage
light blue :) meet you halfway :P
http://www.nengun.com/image/catalogue/orig...l_injectors.jpg
Edited by URAS
In all seriousness Trent, have you driven this car or been for a drive in this car on the street? When it hits boost and makes that 800+hp in 1000rpm, do you actually see into the future? That thing would have to chirp 5th!!
Congrats on the result trent!
Id love to see some footage when it hits the drag strip :mellow:
Ill sit on the roughly fixed amount of drivetrain loss rather than the % theory. This car is a perfect example, i mean im pretty sure that the temp of the gearbox and diff doesnt increase almost 400% when the power does so going from stock maybe 300hp to say about 1100hp.
Back on topic, as someone else asked what ebc was the car running?
It all comes down to the fuel being used, the fuel pressure setting and the air:fuel ratio. It is impossible to make blanket statements like the one above.
Think about it for a minute. What power would those injectors support at 60psi base fuel pressure but running Methanol? How about oxygenated leaded race fuel? PULP?
It might be a good general guide to say that 1000cc injectors could support 1000 engine horsepower at 45psi base pressure and 12.5:1 but to make claims about any particular setup's capabilities without knowing the fuel type used, the pressure, the air:fuel's and the injector size is foolhardy at best.
Here we know that it was running 1000cc injectors, I've had a 'stab' that it's running Sunoco MaxNOS (as it's the new hotness;)) but we don't know the fuel pressure the reg was set to or the AFR's tuned to. Let's say 13:1 and 65-70psi should be enough.
Possible but more likely that the 1002hp is a great indication of flywheel horsepower.
The terminal speed on the timeslip (if this car ever makes a full noise pass down the quarter) and the race weight of the car will give a better, more 'real-world' comparison and idea of the power the thing is making.
***EDIT***
I had to laugh at the genius of an engineer above too!
I have highlighted the operative word. I was merely stating what they are capable of. Sure there are other factors involved but that would be my estimate at their maximum capability with all variables taken into account. Perfect A/F ratio, good base pressure etc etc.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
