I have highlighted the operative word. I was merely stating what they are capable of. Sure there are other factors involved but that would be my estimate at their maximum capability with all variables taken into account. Perfect A/F ratio, good base pressure etc etc.
Lipstick on a pig, champ. Even trying to get an accurate look at the capabilities without all of the aspects you failed mention in your post is silly. Imagine it's running a 'heavy' non-oxygenated fuel for a moment, something that burns nice and slow that you can lean out quite a bit and that the base fuel pressure is 75psi.
What are the 1000cc injectors worth in horsepower terms then?
  • Replies 374
DiRT smelled a rat...and indeed his nose has been vindicated...there was something not right and now its been highlighted by the tuner as fact.
Ok...back to discussing this monster R34
My balls are far too small to drive a car that nuts on the road! Yes H@ME the owner certainly is looking over his shoulder for the men in white coats.
Im having trouble working out what is more awesome in this thread...this car...or Johnny's avatar.
Edited by DiRTgarage
i vote for johnnys avatar happening on the bonnet of this r34. win win.
and i take it you mean the injectors infact being different to what was stated as the rat..
regardless tho.. well done trent great work.
yes...rat = injector size that was stated
not anything to do with any person, dyno, drivetrain losses etc
Im tempted to jump on the plane and come down to MAS to see it unleashed.
Ok so you're saying that 1000cc injectors are not capable of supporting 1200 engine hp?
And it's even more silly to start adding variables. Sure, change the fuel, change the base pressure....the 1000cc injector can still do it, just not with that arrangement. So you haven't disproved anything. That's like the guys from Bugatti saying their Veyron can do 400 and you say, oh but can it do it against a head wind with flat tyres? uh ah!.
No it can't do it against a head wind with flat tyres...but it can still do it.
Quite the opposite, champ. I see you have misread/misinterpreted what I meant. No matter.
My point was that it's silly to make assumptions and guesstimates without knowing or at least having a pretty bloody good idea at what the other variables are.
so trent what injectors is the car actually running? brand? size?
indy blues, they look the same only the indys have a black body not silver..... 1600cc. i think it is covered on page 6 http://www.skylinesaustralia.com/forums/Tu...html&st=100
Edited by Revhead
indy blues, they look the same only the indys have a black body not silver..... 1600cc. i think it is covered on page 9 or 10??
interesting... wats the idle like.. i assume you'd probaly have troubles getting it down to 1000-1100 range with injectors of that size? than again.. the cams in that thing would be rather large and probaly prefer an idle around the 1200rpm mark?
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
