Im almost off my L-Plates and Ive been driving around my Dad's R33 GTST as on my L's im allowed to with parents in car.
However when Dad bought the car I payed for it because it is gonna be mine, but this was before i read up on P-Plate restrictions. I read about Special Exemptions that allow for permission to drive the car if it is passed down by a Family Member.
If anyone has info on this or has done it could you pls post here as I will miss driving it for the duration of my P's.
https://www.sau.com.au/forums/topic/237333-need-some-help/
you gotta check with the rta for this,
my wife can drive my car cause it's the only car in our names(not that i'd let her drive it anyway).
i heard from some people that if you own the car before you get your p's or l's you can drive it but it has to be in your name. not 100% about it though
https://www.sau.com.au/forums/topic/237333-need-some-help/#findComment-4152054
i never had to look into this because i got my p's before the laws came out, but from friends of mine that have told me alittle about it what i gatherd is you can get an exemption if its the only car your family has and its not practical to buy another car,
if you have a legit reason for having to drive it on the street (cant think of an example lol)
and i think there is a way to get an exemption after you get onto your green p's if you have not lost any demerit points in the first year of driving and not had any accidents, but if you are on p's and have an accident in the car or get caught speeding in it you loose the exemption untill you get off your p's.....
im not 100% sure because i wasnt the one who researched the topic, ask RTA
https://www.sau.com.au/forums/topic/237333-need-some-help/#findComment-4152119
1) If you get that exemption, I'd get it in writing and carry it with you in the car
2) I'd then check with the comprehensive insurance co. to confirm that your car is covered along with that exemption.
3) I'd then inform the CTP co. that you are under 25/30 and that your premium is adjusted
Possible #4) If the car has mods (depending on what they are), I'd get an engineer's certificate and carry that around on you too
Then you are ready to meet the Police.
Have fun mixed with safety :P
https://www.sau.com.au/forums/topic/237333-need-some-help/#findComment-4153662
    • TBH, it sounds like the threads on the bolt are fubar in a specific section. Most likely as you've been working it back and forth it has torn threads out, as you loosen the bolt, this section enters the nut, now you're spinning a round shaft inside the nut, there's no threads here.   Use something similar to a claw on a hammer that will fit either side of the bolt head and try to apply downward force while also undoing it. The idea is to attempt to catch a thread, or just rip the f**ker out. Caution on ripping out, as it could bend/maime/mangle what the captive nut attaches to. If the captive nut is actually okay, you could do the dirty part of cutting the head off the bolt, then cut a slit in the end of the thread that's now exposed and then screw it up and into the area the captive nut is until it falls out the other side. However, this does risk the remainder of the bolt rusting over time and damaging near the captive nut and also making it rust. However, so can cutting pieces of panel work out to access this area if you don't reseal it properly.
    • Well, every piece of information on that part when you track it back to Nitto says it's for a KIT of theirs. It is also designed thicker to be stronger. And they speak about a specific harmonic balancer bolt they supply for the whole setup.
    • Techniques for removing stuck bolts are: hitting the bolt head with a hammer, heating the bolt to red hot then letting it cool and working it back and forth like you are already doing. AFAIK the idea is to try to crush whatever material is stuck between the threads (and heat also melts locktite but that's almost certainly not relevant in this case).
    • Yuh, I think it works with the Nitto gear only. I presume that you're not also using the Nitto gear? Watch the video. Compare the interface between the Nitto gear and washer (on the gear side) vs the stocker and decide if you think the Nitto gear is different from stock there.
    • Liking the new charger, battery all good (I think).   Also like how you can put it in power supply mode too. Will troubleshoot with that sometime soon.
