Item: 2 x R34 GTR Wheels Keyring (Brand New with Box). $25 each
Item: 1 x 350Z Wheel Keyring (Brand New with Box. $25
Item: R33 series 2 full mats set (Perfect condition) $ 120
Item: R33 Series 2 cluster ( Speedometer doesnt work ) $50
Item: R33 GT side badges (Good Condition) $30 both
Item:4 x R33 rear fascia. $35 each. 4 for $120.
Item: R33 engine Damper( Brand new comes with bolts) $70.
Item: R33 Gear and handbrake Boot. ( Brand New but not the best leather) $ 25 for the set.
Item: R33 Windshield ( Perfect Condition with clips) $80 for the set.
Item: R33 GTR Model kit ( Brand New untouched but without seal packaging) $25
Item: H3 MTEC 4,750K Bulbs ( Brand New) $ 28
Item: Hella Horns (Brand New) 110db rating $30.
Item: Rb20/25 air filter adaptor (Used) $10.
All items exclude cost of postage.
Pick up is available in ADELAIDE. Thanks
Edited by Giveitall
mate do u no why the speedo wasnt working???
is it the cluster or speedo cable??
if its in working order(cluster) ill buy it how many km on it. hopefully around 120km thats whats on mine atm
cheers
cheers
buddy, Someone sold me a dodgy one. i checked it. its was ripped open around the speedo mechanism. so..def not working
Will give u $10 if u ship a keyring to me :cool:
let me know your bank details etc :P
cheers however you can keep your $10 then. thanks for your interests
Item: 2 x R34 GTR Wheels Keyring (Brand New with Box). $25 each (1 pending sold)
Item: R33 series 2 full mats set (Perfect condition) $ 120 (pending sold)
Item: R33 Gear and handbrake Boot. ( Brand New but not the best leather) $ 25 for the set. (pending sold)
Item: R33 GTR Model kit ( Brand New untouched but without seal packaging) $25 (SOLD!)
Item: Hella Horns (Brand New) 110db rating $30. (Pending SOld)
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
