ok i've been looking around for aftermarket manifolds for the rb25 with no luck.
im looking for something that will fit the turbo in the original "side mount" position that could allow me to run an external gate. so i thought why not drill a hole in a stock one? but i've been told that the welds might crack? my budget is not so big and a custom manifold is not an option at this stage.
has anyone done this? i would like to hear from people who have tried it, any other suggestions are welcome.
:banana:
:P
I've done it before...
I got my brother to do the cutting and welding for me, not that hard just get to 90 degree butweld fittings, cut the hole in the back of the manifold, scallop one 90 degree to fit on the back of the manifold, line up the other fitting and weld... make sure you bold it down when heating the manifold so u don't warp it...
thats great info mate, thank you. a few questions
1. how did you drill the hole?
2. do you need to heat the manifold red hot before you weld?
:P
:P
as for the whole.. pre heat the metal than oxy cut the whole.. than die grind the rest would be the easiest
not red hot.. just cast needs to be pre heated and post heating after welding.. around the 200degreeC mark should do it before welding to avoid cracking.. and it needs to cool down very slowly... so no dipping it in water after its been welded!
we tried an oxy first but the cast is sh)t so it was a pain in the a$$ ended up gouging it out...
we didn't preheat or post heat, just mig'ed it up.... only problem was warping which is why i said bolt it down when cutting and welding...
ok i dont have an oxy :P how about drilling it? then get an exhaust place to weld a pipe and connect it to the dump pipe, or i can borrow a friends welder.
if not how hard will it be to make the bends in the pipe my self, im good with tools just dont know how i'd bend the pipe into the right shape.
You cvan go 3 ways.
1. Spacer plate inbetween the manifold flange & turbo flange with a gate hole
2. Off the manifold (as shown already)
3. Off the turbine housing itself
All 3 ways have been done before, and i cant think of any disadvantages to any.
Depends on the setup your working with, size of turbo, size of gate as to what would best suit your needs as everyone is different.
Cheers
You cvan go 3 ways.
Cheers
thanks nismoid, i'll be definatly doing it from the manifold. do you think i'd be able to drill the manifold instead of having to do it with an oxy?
:P
Not sure, never been involved with that myself... although there are a few different ideas so far in this thread.
spacer plate would be my choice though (if i could fit it in). Each to thier own
Putting a wategate off the exhaust housing can cause turbulence... you could drill it but it would take a long time as u'd have to use a small bit and drill about 30 holes to do the circle, also the manifold is split in the middle so 3 cylinders/runners per side, i'd mark it out and take it to a Fab or engineering shop and get them to oxy or gouge it out, also u'll need them to scallop the wastegate pipe that goes over the back of the manifold as it's not a circle it goes down the back a bit, buy the buttweld fittings from Bunnings should cost less than $15 for both...
#3 is so ghetto
sure is, however ive seen it on a r33 years ago and the guy didnt have any issues from memory.
sounds like i'll need to get the pro's on this then? any ideas of costs?
would it be a better idea just to take my manifold, turbo and dump pipe to someone who can do it in one hit? suggestions on places would be great. located in sydney.
:ninja:
Measure it all up then take your manifold wastegate flange and buttweld fittings to somewhere that can do it... wont need your turbo or dump...
after you have it all done take it to an exhaust shop to go from the wastegate to your dump (thats if your not running a screamer pipe... well you'll need them to make that for you anyway.)
an advantage to this way is that the exhaust gas is been flowing into the wastegate without restriction, as it's in the exhaust gas flow.
Edited by axe s
thanks for all your help mate, i'm now clear on what needs to be done :mellow:
what do you guys thing about ceramic coating the manifold after its all done, does it cost alot?
:rant:
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
