U drivin?im not :mellow: i wish next yea ill hav my car u drinvin ya r32?
yup my r32 4 door is my drifter, dont worry save ur dollars, build a reliable well thought out car for urself and ul be choppin skids in no time
https://www.sau.com.au/forums/topic/237421-drift-practice/#findComment-4156340
get ur vl out there lol... i took my shitty old vn for a drift a few months back
Its auto and got body roll like a 300kilo fat man :(got make it last aswell only car i got atm and a bit straped for cash,anyway im buying a r31 taking it of the road and preping it for track only car should be up and running by late this year or early next yea coz i dont even have it yet :P this is a idea i might steal :cool:Chop top
Edited by Daniel vp
https://www.sau.com.au/forums/topic/237421-drift-practice/#findComment-4158613
Its auto and got body roll like a 300kilo fat man :(got make it last aswell only car i got atm and a bit straped for cash,anyway im buying a r31 taking it of the road and preping it for track only car should be up and running by late this year or early next yea coz i dont even have it yet :D this is a idea i might steal :cool:Chop top
imo, i think the chop top thing would be a waste of time and dollars, also to mention that it will be severly scrutinised structuraly, just be it cheap and get the 31, mini spools for their diffs are cheap off ebay and there ya go uv already got ur locker just stiffen up the suspension, get rid of EVERYTHING u dont need and get a clutch with a decent enuff clamping pressure and ur set to go
iv built my r32 4 around 6500 so far, shes light makes ok pwer and handles better than i could have thought, if u look at my pic peels smoke good enuff
https://www.sau.com.au/forums/topic/237421-drift-practice/#findComment-4158951
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
