DR drift qouted me 1350 to fit daughter board and tune it. Now for anthor 300 i can get a PowerFC fitted and tuned with hand controller. I dont see why you would go to a nistune from dr drift when you can get a gand controller and have the ease of getting it tuned anywhere by almost anyone.
Well that is my 5c anyways. Something as important as a ECU i would spend the bigger bucks and do it once. So to speak
  • Replies 47
Posted Images
hey toshi, siddr20 says its $400??
is that just for the daughterboard data??
coz.. im interested in getting one of ur remap boards..
but yeah..
so what the deal? you send me an R33ecu, with a daughterboard installed with tuned data?
for $700-850...and then i just send mine back to you...that correct??
$400 remap ECU (exchange)is not installed daughterboard.
It is installed hitachi H8 PLCC chip.(local tuner can not tune)
I will send remap ECU to you and you go to dyno shop for check AFR and ping.
If my remap chip will lean , ping , no power etc I will send another chip.
If you are living in Sydney I am able to real time remap tune by NISTUNE software.
Daughterboard installed ecu(exchange) and data depens on exchange rate.
AU$1 is 65yen today.(it was AU$1 is over 100yen)
I think over $1000 now.
Also $400 remap chip will change price.(I have instock only 4 chip now)
Im thinking around $500.
@ greddy skyline
Get gaven woods to put the PowerFC in mate you will not be disappointed. He is the only guy that has found and fixed every problem I have had. He might cost a bit more but is well worth it. My car is going back into him very soon for a retune on my Skyline because I have put some new parts in.
If you have any questions about gaven send me a pm
hey mate Ive taken my car to Gavin a few times now for regualr servicing and some fixtures.
I would take his word over others bcause ive seen his work and its impressive.
unfortunately when I wrote this thread i was still interested in an ecu but now ive come to a slight decision to hold off and save a few more $$ towards a GTR or 34GTT
and not only that my clutch is slipping so Gavin is installing a new one this tuesday.
so there goes my ECU money haha :kiss:
  • 11 months later...
is that 1350 for a nistune? if so, that is pretty steep.
EDIT: JUST REALIZED HOW OLD THIS THREAD IS, TOTALLY FORGOT I WAS USING THE SEARCH FUNCTION AND NOT READING UP TO DATE FORUMS. MY APOLOGIES.
Edited by WARLORD BAS
Well under $1000 almost anywhere supplied fitted and tuned for Nistune, Almost all Tuners now tune Nistune.
yeh i know ay, i got mine done for $750 including plug wiring for z32afm.
thats why i just wasnt sure if the price he was referring to was for a nistune or something else
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
