Kodak Silver gold cd's are very good for mp3 / vcd burning. Nero is very good for mp3 application. What player do you have? I have the same prob burning ripped vcd clips, some work fine, others are a bit scratchy. sometimes it can be blammed on what speed they were ripped at origionally, and how you computer decodes them.
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-508789
it shouldn't matter what program u use to record mp3 .. as long as it follows the right format .. or am i getting the topic wrong?? if u're really worried about quality ... then u should burn at the slowest prossible speed ... when listening to mp3 its very very noticeable when a disc is scratched .. the errors are very obvious and not easy to hide ..
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-508823
The biggest problem with car mp3 is when you have a mixed CD to play. Between the mixed songs is a pause that is very frustrating and bad to listen to.
When making the mp3 (if you guys do this) - make sure to rip the mixed cd into *one* file - EAC (exact audio copy) is brilliant for this because it also rips *digitally* ensuring highest possible quality. Use the copy range function. If you don't use EAC currently, after using it and hearing the difference you won't go back and you won't accept 'popping' in you rips.
Be sure also to use LAME mp3 encoder with VBR (variable bit rate) to encode a cd with exact quality as original (according to our human hearing). EAC will automatically set you up with the correct LAME settings to achieve this.
Here's a bunch or URL's to get you started:
Lame d'load
http://home.pi.be/~mk442837/
EAC d'load
http://www.exactaudiocopy.de/
A little bit of information about the combination
http://www.afterdawn.com/articles/archive/...ydeneaclame.cfm
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-508840
cd audio can be played right after each other, but mp3's cannnot due to their file system
no matter what program u use, an mp3 will not play directly after each other.
i also have the problem, mixes that go onto the next song i burn on audio cd.
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-508912
so how do u guys manage the cd? with about 150 songs it gets pretty messy ... and with my deck its can take a long time if its not organised into files ... hehehe ... another thing annoying is when u listen to chinese music or something similar the deck can't display chinese characters ... annoying .. :)
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-524196
Depending on the player you can get a crossfade plugin. This fades the previous tracks last few seconds and the next tracks few seconds together and creates a much nicer transition than the usual harsh stop/start.
Not sure about car based mp3 head units, but certainly winamp (used to use it when i ran windows) and xmms (using this at the moment) have the plugins availability.
I'm not sure about xbox media player, but I'm sure its been done and thats what ill be running... :)
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-524342
I forgot to ask..
I've been using cdparanoia and lame with the highest quality VBR mode for ages - works very well. How does cdparanoia compare to this EAC - Torrens?
I have found that cdparanoia is EXCELLENT for ripping less than perfect audio cd's. It has many many options and can be set to attempt to rip a track indefinitely until it succeeds.. it will retry and retry to read the scratched part of the disk - and most of the time it eventually gets there - though it used to take quite a while on the old 2 and 4 speed drives.... It has been around for a very long time..
From the man page (yes it is linux based EDIT: though apparently its multiplatform - I've only used it in Linux and maybe some of the BSD's - dont remember):
CDPARANOIA(1)                                                    CDPARANOIA(1)
NAME
      cdparanoia  (Paranoia  release III) - an audio CD reading utility which
      includes extra data verification features
DATE
      version III release alpha 9.8 (02 Mar 2001)
SYNOPSIS
      cdparanoia [options] span [outfile]
DESCRIPTION
      cdparanoia retrieves audio tracks from CDDA capable CDROM drives.   The
      data  can  be  saved  to  a file or directed to standard output in WAV,
      AIFF, AIFF-C or raw format.  Most ATAPI, SCSI and  several  proprietary
      CDROM drive makes are supported; cdparanoia can determine if the target
      drive is CDDA capable.
      In addition to simple reading, cdparanoia adds extra-robust data  veri-
      fication,  synchronization,  error  handling and scratch reconstruction
      capability.
More Info: http://www.xiph.org/paranoia/
I use GRIP to tie these both together and do all the CDDB fancy stuff - ends up being really easy. I found it was much harder trying to sort out the shareware and stuff in windows..
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-524354
I haven't seen (or should that be heard?) paranoia in action so its difficult to make a comment.
EAC is the ripper of choice for Win32 - as it does rip digitally unlike all other rippers.
Seriously people, your simple rippers might seem easy and quick, but you're really missing out on some quality rips - I mean like perfect quality rips. If the source rip is imperfect, the final mp3 is going to imperfect and worse too. You will find the pops and clicks unacceptable. Yes, you can notice the difference.
Also VBR is the best for sound reproduction, which is more important for those who are looking for quality over the 10% or so filesize difference.
I recommend using it for yourself, and doing a comparison - you won't turn back, and you won't accept inferior rips again.
For those who use winamp / media player and have pissy little speakers (i.e. non hi-fi type equipment), try DFX (digital sound processor) - great enahancment in sound.
fxsound.com
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-525212
Yeah, I did some research on cdparanoia - looked at their website etc.
Seems the latest stable release is some years old.. some things just dont need to be improved :)
According to their site, it does a direct digital copy and even talks about Exact Audio Copy in some very technical discussion regarding the way it attempts to read the data off the disc.
Seems cdparanoia is still the way to go on linux and EAC seems ace for windows ;)
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-525267
What sort of VBR settings are you using? VBR is still pretty new to me.. haven't really encoded a lot of MP3's in the last few years.
It still amazes me how quick you can create MP3's now days. Back when I was really into it, I would have to encode an album overnight to get really good quality.. go the latest and greatest pentium 150.. ;)
I use the following lame settings:
-q 0 or -q 2 -> highest quality algorithms .. not sure of a huge difference here
-V 0 -> highest VBR quality
Be interested in finding out what other people use..
By the way - file size does not concern me at all.. I'm actually interested in playing with flac (lossless compression - ie. exact reproduction)- hdd is so cheap nowdays, who cares :)
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-525288
i don't understand why variable bit rate is better ... i'm assuming that it means when the song gets encoded, a higher bitrate is used when it is needed and lower bitrate when its not needed .. now if u use a high bit rate all the time then it doesn't matter right?? am i correct??
https://www.sau.com.au/forums/topic/23753-mp3-recording/#findComment-525369
    • I can't help with the clearance question, I've always taken my machine shop's advice on that. It is worth considering that a shop that does that every day for road cars will be looking for as good as they can get off the shelf, not perfect. If you want more careful race style "blueprinting" then you need a race shop to measure/machine the engine. I do have an opinion on line boring the block though....don't do it unless you have to. The crank centre moves higher but the oil pump stays in the same place when you line bore the block.
    • Hey that reminds me, are you changing your forum name to "The Hairdresser" too?
    • There's no figuring out with a Haltech, you literally load up the base map, plug in the vac/boost reference from your manifold to the ECU (or an external MAP) sensor, wire up an IAT and it will run pretty well out of the box. The ignition tables are quite well defined and safe enough for someone to give it a hit (although I don't recommend it if you've got anything besides the stock gear on the motor).
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
