Item:R33 GTST S2 Front end, comes with Head lights in good condition, front bar with fog lights attatched and a Carbon fibre bonnet for S2 - the carbon fibre bonnet not in good condition but works normally
Age:unknown!
Condition:bar and lights good, bonnet average to bad condition but does the job!
Price:$1000 FIRM
To Fit:R33 GTST s1 or S2 (What car)
Location:Newcastle - PICKUP ONLY - can organise to be delivered close by for a price
Contact:Me 0412417579
Comments: Pics will not be available till the weekend. I WAS going to keep this for my car but i need some cash desperately, this front end was on a Series 1 but it is a S2 front end!
Item:RB25DET Engine
Age:13 years??
Condition:Good!
Price:$1100 !!!! CHEAP
To Fit:Anything :thumbsup: (What car)
Contact:ME 0412417579
Comments:This RB25DET has NO coilpacks (but can supply a set of S2 coilpacks and loom for a extra $100 and has NO turbo. It does have all the turbo lines and the inlet manifold is complete with throttle body and exaust manifold is there. I need this Gone ASAP as i need the money so its going for CHEAP - working engine, i have seen it running for a few hours before i pulled the car down and it did not blow any smoke ran properly etc etc.
Engine comes complete
Minus coil packs and coil pack loom
Minus Turbo
Harmonic balancer / power steering pump INCLUDED
Starter motor if you need one little extra (we can neg)
Inlet manifold side complete with throttle body and injectors & wire loom INCLUDED
Stock AFM & Pod filter INCLUDED
Take this off my hands and make some cash!
Item:R33 S1 steering wheel
Age:same as car
Condition:good
Price:$100
To Fit:r33 S1 (What car)
Contact: ME
Comments:good condition wheel. $100 pickup only.
No time wasters please. this is going cheap as and won't last long so if your not sure don't bother me im busy!
Sorry forgot to mention, the altanator is included with the engine and the CAS is there as well as well as the engine harness.
Have a 3" turbo back exaust.
Includes dump pipe and front pipe (in one) and catco 3" cat and full exaust with big cannon on rear. looking at $400 for the LOT!!
If you are not able to get rid of it quickly would you consider separating and shipping the s2 front bar to Melbourne as that is all i need.
Please PM me if you happen to change your mind.
-Jack
not seperating anything. This needs to go as a whole. Ive seen front ends like this go for over $1500.
someone snap this shit up! make a decent offer
forgot to mention it ALSO comes with a S2 aftermarket grill, its a GTR one i think has a big area in the middle.
Would be keen to see pics of the front end!! has the bonnet just gone shitty an oxidized or is it actually damaged?
You sure you dont want to post? I could be up for a road trip though :cool:
i think the front end is sold. I am def not keen to post it. i just cannot possibly do it. sorry guys.
Surely someone wants a nice cheap RB25DET ? i know im going to regret selling this later!
You sure you dont want to post? I could be up for a road trip though :merli:
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
