This is based on my first hand experience. Please dont ask me for opinions, as I do beleive that it would contradict the rules of this forum.
I originally ordered the plenum in the early part of this year, and had paid in full - $890 to supply a plenum with ford throttle body. As a full bolt on that allows all factory options such as idle control to be run.
When I asked them to send it to me, it was a few months later, he told me then that the throttle body has a ford TPS and would not work as it was with a nissan. I was also then told that the throttle butterfly had a couple of small holes that I 'might have to do something with'. Fortuneately I did find someone who filled the holes and was able to make an adaptor for the ford throttle body to nissan TPS.
Upon receipt, I discovered that the flange that the throttle body mounts to was to suit a factory nissan skyline throttle body, not the supplied (second hand ford explorer) item. Also the bottom of the plenum had been welded after it had been faced, then finished with an oil stone which was close enough. (this is because I rang Hills and asked why it wasnt faced). So I sent the plenum back to have the flange for the throttle body changed. This was promised to be done on the day it arrived, and overnighted back. I overnighted the plenum to Hills, it came back 4 days later.
Upon fitting it was discovered that there werent enough places to attach vacuum lines, so I had to have a block made up and tapped it into my PCV line. Also, where the brake booster attaches to the plenum has been located behind the AAC valve, so to adjust it you need to remove the brake boost line first, hold your hand over the hole and use a very short screw driver as otherwise it is impossible to access the vavle. A couple more surprises.
Finally today I found the source of my vacuum leak that had been making impossible to maintain anything close to stable rpm below 11-1200. The throttle body flange is not true, by close to 1mm, causing quite a severe leak. I have tried using thicker gasket paper, didnt work, tried using 3bond, didnt work.
So I now have to remove the plenum and take it to get it faced. I hope there are no more surprises. This is becoming a VERY expensive exercise.
Trust plenums cost $1100, bolt straight up, and work well.
I will soon have a hills plenum for sale if anybody is interested, please pm me.
https://www.sau.com.au/forums/topic/23760-hills-motorsport-plenum/
  • Replies 60
not the greatest to here people getting stuffed around.
i got my plenum done. Just refaced, and as far as i know it hasn't missed a bit. For 250 bucks and the sake of closing the bonnet, was very worth while.
I guess thats a difference, some companies dont really pride themselves on what they produce.
Its all about the $$$ factors. If they had taken that little extra time to make your plenum, but had got it spot on, i am sure you'd be over the moon....
best of luck.
Thanks guys.
I hope by posting up here that someone can learn from my experiences, and hopefully dont end up with the dramas that I experienced.
Now to find a replacement plenum. I would love to get a trust one, but they take ages to get here and I want to get my car back on the road. If I persist with this plenum, I am not sure how much more it will cost me to get it sorted - it is becoming a money pit. At the minimum I am looking at remove and replace, gaskets and the cost of facing. It is one very expensive plenum.
I have the Graddy plenum and haven't had any issues with that. I also have a 100mm throttle body, and that doesn't cause any major issues either. I think both purchases were worthwhile, but can understand your frustration when things turn into a drama.
Hopefully, soon I will have a trust plenum too. It sort of shits me because not only do I need to buy another plenum, I will have to get all the pipework redone. It cost me nearly $400 for the pipework, gaskets, fitting and vacuum block needed with the Hills plenum. And of course I need to retune the bloody thing again.
Which throttle body are you using? Is it the infinity one? What do they cost? cos it might be more worthwhile than using the stock one as an adaptor cost $150.
Cheers
Originally posted by sidewaymambo
Tony, how' s car goes now?
Car is almost ready. All the internals are done, port/polish head.
Problem is that I'm doing a lot of stuff along with it (ie. oil cooler, remote oil filter kit, hopefully cams). Like all rebuilds, the price has blown way out of what was planned.
It should be ready the CRD dyno day early October.
I hurt my left hand so I'm not able to drive manual cars much anyway.
How much is a Q45 TB btw.?
The car has been up on stands for quite a while now.
T.
I am hoping that I will get a refund, just need to find a trust plenum asap so I can get my car running ok, then return the hills one and hope for the best.
Do you still have the adaptor to stock throttle body? I may be inerested in unloading it off you. Also, where did you get the trust plenum from? did they order it or do they carry stock? also, roughly how much did it cost if that isnt a rude question?
Cheers
Steve
AFAIK the Trust plenum is ~$1,000 from a number of sources. I'm still arranging to get one.
The rb25det adapter is $100 more.
I think Philip is saying the z32/q45 adapter bolts straight onto the plenum (ie. no adapter plate needed).
So your $100 is better put towards a new TB.
How much is a TB btw.?
T.
Hi All,
Steve, I sort of feel a bit responsible for your plenum issues as I had posted details of my Hills plenum on this forum. I also recall that I gave you Hills phone number (I think).
As you know, I had some issues with Hills myself - if anyone wants details, PM me as I don't think the forum rules would alow me to state the facts surrounding my Hills experience.
Nuff said...
I too am looking for a new Plenum - so if there is a two for the price of one offer going, I'll be in it ! The only caviat is that it must be a tried, tested and proven part.
I hope some people learn from Steve and my experiences.
Cheers,
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
