R35 Gt-r Order In Us Was Canceled Due To Fitment Of Electronic Data Recorder.
Link to full story but a bit of the story is below.
A Florida man named Scott Weires has canceled the order for his long-awaited Nissan GT-R. Why? It's not that he was disappointed in the car's performance credentials, far from it. The problem is that the GT-R is equipped with a 'black box', similar in theory to the kind found on airplanes to help determine what went wrong in case of an accident or breakdown. By the end of 2012, car buyers won't have a choice as to whether their new car is equipped with a 'black box,' or Electronic Data Recorder -- they will be federally mandated to carry one. These devices track information that could be useful to the manufacturer in determining exactly what is, or has been, going on with a car. There are a few worries, though, that warranty claims could be denied if the automaker, Nissan in this case, deems that the car was being raced or abused in some way or by police or lawyers to determine culpability. Nissan's GT-R carries an on-board recorder that keeps track of the past few day's worth of driving and cannot be disabled. In the case of Scott Weires, an attorney no less, that was enough to look elsewhere. Would it be for you?
That is pretty lame on the guys part.. he has limited his choices somewhat if all new cars need to have them by 2012 :mellow:
I wonder if it is a US only addition to the ECU?
I really dont see the point of this thread...
So what if captain America hates the black box.
Not everyone does you know...
I like black boxes.
Yeah you wouldnt like it if you were going a little over the speed limit, hit some oil, spun off the road and Killed someone -
The Crash investigators would determine you were speeding thru the black box, the media would sensationalise it and say you were doing 300 km/h in a 300 km/h supercar, the government would probably ban it, and you would be thrown in jail for killing someone.
They're limited to 180 Kph so the media can't claim 300 Kph ;-)
No theyre not, necessarily.
Mines makes a chip that delimits the engine.
My buddy here in japan has one.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
