My PNV doesn't weigh 1320kg ....................... where did wikipedia get that information from????
A DR30 weighing 1320kg would be considered a BRICK in my humble opinion!
anyone know where you can get this data from? Out of a JDM Sales Brochure would be a good start???
Also the power figures. Same place I suspect???
Did some come standard with RB20 engines? ................... NO! Definitely NO CHANCE!!
To answer your questions more accurately, I need to know if you have a 2000RS or 2000RS-X and Sedan or Coupe and Manual or Automatic, hence why I asked in another thread, WHAT CONFIGURATION, yet everyone just thought I was being a smart arse.
It's so little what they really know!!!!!!
https://www.sau.com.au/forums/topic/237636-kerb-weight/#findComment-4160070
sorry to hi-jack but out of curiosity how much did the 1984 RS-X manual, coupe weigh :(
Is 1150KG about right? thats what I allways thought to of believed .... also is it true the 4 door sedan weighed a slight bit less? due to the coupe having alot of re-enforcement in the roof because it was pillarless
and was the RS-X C only 85?? or some 84 aswell?
https://www.sau.com.au/forums/topic/237636-kerb-weight/#findComment-4160254
HR30 l20et engine, is 1150kg, the other models go up Kg's due to all the electrics they got.....
only offered in l20 or fj20 engines
r31 rule of thumb is around the 1300kg mark.
import models came in rb20et - rb20det versions from nissan
local models all got the rb30e
https://www.sau.com.au/forums/topic/237636-kerb-weight/#findComment-4165588
Correct. My GT-ES.. (no power steering, No power windows. Limited stuff) is around 1120kg..
https://www.sau.com.au/forums/topic/237636-kerb-weight/#findComment-4166128
From what I can decipher on the sales brochures, the 2000RS (KDR30JFT) FJ20ET poverty packs weigh 1185/1195kg and luxury optioned (full electrics) 2000RS-X (KDR30XFT) vehicles weigh 1225/1235kg.
Maybe StagefumerII can put more light on this from the brochure he has?
Cheers, D
https://www.sau.com.au/forums/topic/237636-kerb-weight/#findComment-4166600
Cheers, D
YES. Ill find it
https://www.sau.com.au/forums/topic/237636-kerb-weight/#findComment-4170936
  • 3 weeks later...
Cheers, D
The brochure I have has about every spec on them apart from the weight. :P
https://www.sau.com.au/forums/topic/237636-kerb-weight/#findComment-4210325
  • 3 weeks later...
theres no way a DR stock is alight as a silvia. my rego papers says 1422Kg. i think those brochures u are reading are a bit off. have had car on a bridge and was 1360. i no of a r31 coupe wit a fj in that was 1380...
there are alot of diffrent spec r30's weights are all over the place. Mine is confurmed at stock 1170kg.. When i get back home ill try and sort out a good copy of the information i have
https://www.sau.com.au/forums/topic/237636-kerb-weight/#findComment-4258714
my DR30s were registered with gross vehicle masses of 1,505kg (coupe) and 1,495kg (sedan)
Ghostrider must have the same sales brochures as me, as the figures are identical. however on mine there is another row of information that gives laden weight as well.
https://www.sau.com.au/forums/topic/237636-kerb-weight/#findComment-4259121
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
