Hey guys, I'm referring to the car washes where you pay $1 for 1 minute of pressure spray/ de-greaser/ soap etc.
Ok so my engine bay is filthy and all dirty.. Can i just pressure spray it and degrease it without damaging anything.. is it something i can do? how else would i clean it?
https://www.sau.com.au/forums/topic/237640-1-per-minute-car-wash/
Mixed responses you will have for this.
I have used this technique for a friends r32 gts-t at those carwashes and all we did was put a plastic bag over the pod filter.
my ex bmw i used to hand wash all the time as i would was the car and hose it down
my ex r33 i would spray citrus based degreaser in a can over the tough spots and hose down
never had a problem but i would use a chammy to dry as much water as possible then start the car and drive it for at least 15minutes to evaporate any water left
hope that helps
it can be done, but you have to be careful. It wudnt hurt to cover a few things such as Pod, Alternator, Sparkplug cover and the electrical connectors. Thing is, you dont necessarily NEED to cover them, however it will just attract rust. Im sure you dont want your connectors/plugs/pins do develop rust.
This is what i do. I spend say 1 weekend and clean 1 area of the engine bay. I try to take out as many parts as i can, then i give it a good clean with some "Prestone Bug n tar remover" and then polish it off! squeaky clean. The bug n tar remover works wonders on the rocker covers too. I know its a pain but that way i dont compromise my engine in anyway, esp water damage.
Safest option is get a can of degreaser and a cloth and go nuts. Will take you a while, but its better than having water in any electrical system under your bonnet.
+1
This is what I do, only takes 15min if your not too pedantic
You'll be fine :cool:
Most car dealers get a waterblaster, spray the bay with it, then once it dries spray it with silicone, plastic bag over the pod might be a good idea though
If you have an oil squirting air compressed gun, you can put degreaser and water into it and spray your bay, I did that to mine, no rust 4 years after
I did it with my 33, was fine till you hit 4000rpm then it would not rev any more and if you put your foot into it below 4k it would break down all the time, happened for about 5 mins parked it at a mates for about an hour and never had a problem since.
So long as you dont direct and pressure for prolonged periods it will be fine.
As in just spray your degreaser over everything, let it soak for a min then just gently hose it off with the garden hose.
Maybe give certian areas a scrub with a brush if you need to.
Basically avoid hard sprays at areas such as fuseboxes, pods, alternator (although it is low and probly gets wet frum underbody water in the rain anyway) and the lead cover/leads.
If you jam the hose under the lead cover to clean it out then your just asking for trouble.
I used to do this all the time on my Integra Type R, and never had a problem once with cutting out, rust etc etc. Just a nice clean engine! ;) Will be doing this on my R33 today when i was her. As i did a coolant change/flush last night so theres a bit to clean up.
If you put degreaser on and not wash it off properly it stinks like shit though...
In my 33 I spray the shit out of it with degreaser then just hose it off... looks brand new after 5 minutes at home
Not if you use "Simple Green" :(
That stuff smells good hahaha, and its the best degreaser out!
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
