haha i tried to cut neatly using a saw... lol i need to get someone to make it a bit straighter now, then ill put mesh in... i need it repainted anyway so it doesnt bother me how bad it looks for a short time
I got quoted $500 4wks ago to have done:
* Cut number plater part out and patch the side bits.
* Mesh all across the bottom.
* Re-align FMIC.
* Fit airbox over Pod filter.
* Fit an air duct from the Pod down to the front bar.
* Respray entire front bar.
The angle grinders the way to go. I did my M spec bar with one and it came our perfect. No painting was needed. Dremel would take forever and cost a small fortune in discs and I tried the air saw but it was not making a nice clean cut and pulling off the paint. I use an Artline pen to trace where I needed to cut,,,took my biggest cut back by 2mm and then lightly use the grinder to finish it off. I also used some rolled up sand-paper around a can to curl the sections where my pipes go through the outer parts of the bar. Mesh is held in using thick blobs of Sikaflex. I gotta tell ya,,,take your time,,,don't rush it and it will look like a pro did it. A number of people including my mechanic thought I had got it all done by a pro.
I bought the Trust Kit and just let me say,,,it's unbeleivable,,,every nut,bolt,screw,spacer,bracket,,,bloody everything. Even had the replacement washer bottle and a stopper if the cars not fitted with a rear wiper. If you really want an excellent FMIC kit with everything,,,Buy Trust.
Neil.
Neil, thanx for the info but ur a bit late getting to me on it...
i still need to cut some of the front bar support aswell just to fit this big fcuker ..... i got told it was only 640 wide..... but i measured it to be 670 wide....
Sorry mate,,,no pics on the net,,,I do have an SLR that takes great pics,,,but the Boss of this site has been a little slack and not built a web site for me yet.
Kamikize,,,with the trust one you have the trim two section of the electric fan as well as the plasic knob that sticks out and also trim the a small section of the chassis rails and the front bar reiforcement. Again lifes a lot easier using a angle grinder. Sounds scary but its not that bad.
Neil.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
