I want to clean my engine bay and im not sure how... at manual carwash they have engine cleaner option which is apparently water with detergent... is it a good idea to get water everywhere in the engine bay and then just drive away?
https://www.sau.com.au/forums/topic/237689-cleaning-engine-bay/
ive only done it once cos im also unsure, but what i did was cover up pod with a plastic bag use a whole can of degreaser (2 bux at supercheap) spray all over, then just use normal high preasure, but was careful what i was spraying hard at
i didnt really spray at the alternator (spelling?) didnt think that could of been good for it
I hosed down the top of the engine on my Calais once, (because i had a rat which kept dragging dog poo onto the top of my engine, and stashing it there) - and musta got a bit of water on the alternator because it died a few days later.
I'd suggest keeping water away from the alternator+pod.
hey i used to work at a car wash the stuff we use is like 10X stronger than that crap they sell at auto barn try find somewhere where they sell proper products this shit actually makes u choke if you breath it in it gets rid of grease and oils etc sick stuff man i did my engine bay on the GT-R had no problems man there nothing wrong with giving it a high pressure just don't stand to close its not like they were designed not to get water on them they are cars anything that is not meant to touch water is hidden or protected except pods of cores but other than that spray it and get a rag dry it all get another rag clean one! and armaroll and go over it all clean the pipes with it and will come up mint man.
  • 2 years later...
The rat died or the alternator?
Must have stunk the engine out when the dog shit got hot?? lol
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
