Japan 09 - I Need Your Help
Kyoto without doubt is a wicked place to check out and seeing it with some snow would look spectacular its a pretty amazing place. Ninja castle up in the mountains is a good day trip and pretty good fun, I thoroughly reccommend it..
If your after snow accomo in hokkaido, drop me a line as I do alot of booking for crew.
Nijo castle and the trippy nightingale squeaky floors, lol.
I'd be more than happy to help. Drop me a line when youre ready.
I still have every little shred of info i collected while i was there and only just the other day was i going through it toying with the idea of going back in December...
Kyoto is pure magic if youre open to it..yes its touristy in parts but the experiences i had there, while a little exhausting in some ways, were definitely worth the effort and ive never forgotten them.
On to other topics, FA vs LH...its a bit like The Highlander - there can be only one! :(
And we all know where FA ended up, lol.
Yes, with two consecutive world titles :)
Well ive got no issue with being exhausted over there, infact i planned on doing the holiday properly so i get to the point where i actually miss home.
Kyoto interests me most because its more of 'old japan'. And Tokyo is going to make brisbane feel like a rural town in the outback lol
Snowboarding isnt a big issue, ide prefer to theme my snowboarding holiday specifically for that. Ill probably goto Vancouver/Whistler in Canada to snowboard :(
But yeah, ill stop hijacking the thread now..
kyoto is great!
its not as good as people hype it up to be though.
After you find out a lot of the places you are looking at have been rebuilt to look like the original structures (read: are totally new and not old / ancient at all) it kind of takes the magic away.
This is the major complaint from non natives living in Japan.
It is a nice place though :D less crowded than tokyo and osaka but less eventfull
kyoto is great!
pretty good summation. :( I agree with that. I was a bit sad when i read that kinkakuji (golden temple) was re-done in the 80s. and from memory had been rebuilt a few times after the original was burnt down by an angry monk or priest (memory hazy).
Gion was pretty cool at night. eating in a very traditional style restaurant looking out the window at the real geisha complete with entourage making their way to and from appointments along the small cobblestone streets. it was easy to imagine life in kyoto many, many years ago.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
