I have an RB25DET Neo in an R32. The oil pressure gauge reads at 8 on idle and goes off the gauge when revved. An oil pressure test showed that the motors oil pressure is spot on, so it's an incompatibility with the 32 gauge and the RB25 pressure sensor.
My question: The RB20 and RB25 ECU pinouts show that oil pressure information is not relayed back to the ECU so it must go straight to the gauge, hence I'm thinking I can just buy an RB20 oil pressure sensor and fit it with an adapter to the RB25 motor, and this should give the gauge the correct reading without stuffing up anything in the ECU. Sound right?
https://www.sau.com.au/forums/topic/237722-oil-pressure-to-ecu-question/
Seems you're thinking is spot on, champ! :cool:
Schweet :cool:
Bubba: I have this awful desire to keep the car as close to factory in appearance as possible with the exception of a non-factory paintjob :P I'd like to get all OEM gauges working as they should. Next problem to solve, the water temp gauge ;)
water temp guage is the same thing need to use the rb20 sensor but not the ecu one.
and yeah as the others have said use the rb20 oil pressure sensor and you should be right with the oil pressure, my series 1 rb25 sensor seems to work fine with the dash but i'm sure they changed it with the neo
Schweet :)
Bubba: I have this awful desire to keep the car as close to factory in appearance as possible with the exception of a non-factory paintjob :banana: I'd like to get all OEM gauges working as they should. Next problem to solve, the water temp gauge :)
there are two water temp sensors one for the ecu the other for the dash, just fit rb20 water and oil pressure sensors to the neo.
Edited by URAS
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
